Old 03-31-2008, 08:40 PM   #1
mkiiisupra
Default Transmission threads are bored out.
On the oil pan
Dont know how to explain it but basically i can just slide the screw into the hole. Never ran into this before so not sure what to do. I guess someone in the past over torqued it and striped it out >.<
Any ideas ?
1990 Toyota Supra Turbo A/T
Old 03-31-2008, 09:10 PM   #2
carl johansson
carl johansson is on a distinguished road
you could helicoil it.
Carl Johansson
carl johansson is offline   Reply With Quote
Old 03-31-2008, 10:44 PM   #3
Chambers
Chambers's Avatar
Could it be a hole for the "dowel pin" on the transmission to help lining the holes up?
"Stuck in the 80's"
Old 04-01-2008, 11:31 PM   #4
mkiiisupra
naw, leaking tranny fluid slowly from that section of pan....
Mechanic says i need to remove pan, thus draining about 40 dollars in oil >.< then heli coil it...
Question is how hard is it to heli coil it?? what tools are needed?
I was hoping they would be able to do it with the pan on. but i guess not.
So ill prolly do it myself so i can save the tranny fluid
Old 04-02-2008, 12:54 AM   #5
carl johansson
essentially you drill it out - thread it - and screw in the proper sized helicoil. I think you can get a kit for the size you need.
Old 04-02-2008, 01:07 AM   #6
mkiiisupra
Thanks guys, looking into a drill. Been needing one just have not had an excuse to buy untill now lol.
1986 Turbo Automatic Transmission Rebuild? professorbob MKIII Supra 2 01-26-2012 01:06 AM
86.5 auto transmission removal HELP!!! elmer MKIII Supra 13 04-06-2010 10:41 PM
Should I try to rebuild my transmission, or leave it to experts? Busted Knuckles Non-Generation Specific Questions 1 04-15-2008 01:20 AM
Need transmission removal help ASAP FunWheelDrive MKIII Supra 2 03-23-2008 12:35 AM
Blown transmission 1985Supra MKII Supra 2 01-31-2007 07:56 AM
