Old 04-03-2008, 03:22 AM   #1
mkiiisupra
Default Radiator Information
Fluidyne Radiator #FHP 11-86SUP
Dimensions:
Overall /// Core
Width 24.18in /// 24in
Height 16in /// 12.25in
Thick 2in /// 1.5in
Weighs 16lbs
Other Notes:
Includes radiator cap
claims 35% increased cooling capacity
Direct fit and includes all brackets needed
No A/T cooler
Polished
FLUIDYNE - High Performance - Radiators and Oil Coolers
Availability:
449$ w/ free shipping Fluidyne Aluminum Radiator Direct Fit on all Supra Turbo (87-92) $499.00
415$ https://935motorsports.com/catalog/p...roducts_id=191
469$ special order no cancellations mk3 Radiator Fluidyne 1987-1992 Toyota Supra Cooling Fluidyne Radiator, JSC Speed
469$ MVPMotorsports.com - Toyota Supra Page
449$ Fluidyne 86-92 Supra
521.95$ FLUIDYNE RADIATOR
450$ Fluidyne Radiator - 1987-1992 Supra Turbo
417$ www.TurboImport.com - High Performance Parts!
522$ Fluiddyne 38mm radiator
520.91$ They will try to beat competition pricing Fluidyne Toyota MK3 Supra Radiators
469.95$ Fluidyne High Performance FHP11-86SUP - Fluidyne Radiators - summitracing.com
HPF currently has a deal on them for 450 shipped, contact Brandon tell him your from SupraMania - Powered by vBulletin
Haste Radiator # HASP250
Dimensions:
Overall
Width 375mm (14.76in)
Height 648mm (25.51in)
Thick 52mm (2.04in)
Other Notes:
Includes radiator cap 1.3bar
claims 35-45% increased cooling capacity
Designed for the 1jzge/gte motor possible fitment issues
No A/T cooler
Polished
Aircraft Aluminum hand welded made overseas
3yr replacement guarantee in the event of manufacturer's Defect
3 row
Also webside has a 64mm 3 row listed as #HASR250 more info available at Haste Performance Radiator Three rows design
Availability:
299 w/ free shipping https://935motorsports.com/catalog/p...oducts_id=1409
PWR Aluminum Radiator #PWR1973
Dimensions:
Thick 58mm (2.28in)
Tube demensions: 26mm (1in) 42mm(1.65in) 55mm(2.16mm) 81mm (3.1in)
Other Notes:
claims potential for a 5-10 horsepower gain with added cooling
Fits w/o modification
Polished
All aluminum 18 fins per sq in.
1yr warranty
Works with stock fan and shroud
2 row
Austrailian made
TIG welded
Oven Brazed no epoxy core
15psi rad cap included
PWR Performance Products
Availability:
425$ w/ free shipping https://935motorsports.com/catalog/p...roducts_id=192
465$ MVPMotorsports.com - Toyota Supra Page
495$ PWR 86-92 Supra
449$ PWR AL Radiator
504.44$ may beat competitions prices PWR Racing Toyota MK3 Supra Radiators
HPF currently has a deal on these for 429 shipped for these you want to contact Kyle, tell him your from SupraMania - Powered by vBulletin
Koyo Radiator #R0171
Dimensions:
Thick 53mm(2.08in)
Other Notes:
claims 20-30% increased cooling capacity
Designed for the 1jztge
Need to plug off a temp sensor location in radiator (16mm x 1.5mm thread)
Polished
Heliarc welded aircraft aluminum
Nocolok Brazed
1yr warranty
Doesn't have the bottom hooks for stock fan shroud
2 row
No radiator cap included
1.5yr warranty
Koyo Radiator Aluminum. Koyo Aluminum Racing Radiators.
Availability:
423$ MVPMotorsports.com - Toyota Supra Page
436$ Koyo Radiator for Toyota Supra 86-92
400$ Koyo K-Sport Radiator
399.95$ www.TurboImport.com - High Performance Parts!
476.92 Koyo Toyota MK3 Supra Radiators
390$ http://store.driftmotion.com
1990 Toyota Supra Turbo A/T
Old 04-03-2008, 02:58 PM   #2
j3pz
i just wanna say i bought some silicone radiator hoses from driftmotion last year, they were designed for the 1jz and i have a 7m. a little cutting of the top hose and the 1jz hoses will fit perfect.
hmm wonder if there is any real difference between the rads for the 1jz and the 7m, dont see why there would be
Old 04-04-2008, 04:26 AM   #3
SilenceboneSupra
SilenceboneSupra is on a distinguished road
my car has the PWR 1973 radiator and idk bout hp gain........
when i used to have the stock radiator the engine was running hotter then now with the new radiator!!!!
SilenceboneSupra is offline   Reply With Quote
Old 04-04-2008, 11:48 PM   #4
mkiiisupra
Not sure about a horsepower gain either hehe...
Anyone else have any comments about the RAD they put in.. or some installed pics would be great. Just tryin to get as much info together on it before i buy one heh
Old 04-12-2008, 04:14 PM   #5
mkiiisupra
I am leaning towards the PWR radiator myself but not sure. Due to the cost factor HASTE seems like a good option not to mention looks like a high quality piece....
But i would perfer Austrailian made over chinese hehe...
Do have questions for those guys with A/Ts what did you use for the tranny fluid cooler and where did you mount it?
Old 04-13-2008, 05:32 AM   #6
rinso
rinso's Avatar
rinso is on a distinguished road
PWR Radiators are the bomb diggity.
rinso is offline   Reply With Quote
Old 04-13-2008, 10:57 AM   #7
mkiiisupra
Sent them a email about getting a custom one made w/ the oil cooler fan shroud and electric fans on it. We will see how much they want heh
Old 04-26-2008, 08:37 PM   #8
mkiiisupra
No response from them, going to probably order the radiator end of the next month. Was going to relocate oil filter and redo the oils lines at same time and get a PWR oil cooler as well and then use the stock oil cooler for the transmission...
At least thats the idea anyone have any other suggestions?
was going to use this as a guide to my relocated oil filter/cooler set up
Tech Tips - Installing a Full Flow, Thermostat Controlled Oil Cooler & Remote Filter - SupraMania
Oh the reason i am going ahead with this now is a have a pin hole sized leak top right section, causes pressure in my cooling system to be off and contstantly pushes coolant into my overflow till it fills up and spits it out.... lol so becuase of it pushing out coolant i have constant air in my system..
Cuases that waterfall noise and in this case isnt a BHG lol
