Old 04-05-2008, 11:51 AM   #1
Bonz
Bonz is on a distinguished road
Angry Hot Start Problems!!
I have a 90 7mgte that will start from cold will restart straight away when hot but if left for a couple of minutes will not startuntil fully cold. There seems to be no signal to the injectors, no power to fuel pump but when bridged will run,all temp sensors work,cps works, even rewired the cps terminals, efi relay works, main circuit relay works.
Any suggestions?? please not the ecu!!
Bonz is offline   Reply With Quote
Old 04-05-2008, 05:41 PM   #2
supramacist
supramacist's Avatar
Pull codes.
Find a baby sitter.
Buy a honda or a nissan.
But pull the codes 1st.
Old 04-06-2008, 12:56 PM   #3
Bonz
no error codes just done full pin check on ecu still will not start
Old 04-06-2008, 05:34 PM   #4
If the fuel pump is the only thing loosing power then the fuel pump resistor pack or relay (mounted to the passenger side fender) may have failed. Try bypassing them, starting with the resistor pack.
Old 04-06-2008, 07:14 PM   #5
supramacist
Break out the volt meter and start metering any and everything.
Double check all of it.
You'll track it down with minimal effort.
LOL...., did you price hondas and nissans yet??
Old 04-06-2008, 07:15 PM   #6
supramacist
Fuel pump relay???
Have you checked all of your sensors?
Old 04-13-2008, 05:24 PM   #7
Bonz
Smile
sorted problem ecu has fault failing under load thanks to everyone with suggestions by the way i run a cosworth sierra would not consider a honda etc
Old 04-14-2008, 05:37 AM   #8
supramacist
Cool. I wasn't serious about the honda.
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
Down to two possible problems Micahwc MKIII Supra 13 07-13-2008 10:18 AM
starting problems Donovan MKIII Supra 2 06-09-2007 05:53 PM
problems, problems, and problems tone loc MKIII Supra 6 09-06-2006 04:35 AM
Starting problems HELP adellicson MKIII Supra 0 05-08-2006 03:42 AM
