Old 04-07-2008, 12:48 AM   #1
Serge
Serge is on a distinguished road
Default Compression check question...
Hi!
I tried to check the cmpression of my 7M-GE...the gasket on this one is blown and I couldn't warm it up before the testing how the service manual says.
So it says 9kg/cm....when I added a bit of oil it was already 12kg/cm
The question is HOW BAD IS THIS ENGINE? Do I have to change the rings as well?
I appreciate any advice!!!
Thank you!
Serge is offline   Reply With Quote
Old 04-07-2008, 01:17 AM   #2
CyFi6
i dont know the conversion for psi but if you have a blown head gasket you will have low compression. If the compression jumps more than 20PSI i think it is with a wet test you could have a cylinder to ring problem
Old 04-07-2008, 03:49 AM   #3
Serge
I measured a good cylinder...
Compression check when cold gottadiesel MKIII Supra 3 02-26-2009 07:24 AM
compression test question mastergrader007 MKIII Supra 2 08-09-2008 12:05 AM
Compression Question Intenseneal MKIII Supra 5 08-15-2005 10:27 AM
compression check ddmcse MKIII Supra 3 08-03-2005 11:11 AM
