Old 05-13-2008, 09:03 PM   #131
Bill UK
AEM EMS
Bill UK's Avatar
No one touches the Supra except myself, I've set the timing dozens of times using # 6 as stated in document below. (# 6 is at the back) if you have a variable setting on your strobe light set it at zero. It sounds if you may have a doggie HT lead. Does the timing advance when you remove the terminal link in the diagnosis box.
Old 05-13-2008, 09:16 PM   #132
Bill UK
AEM EMS
Bill UK's Avatar
Also make sure the arrow on the pick up clip that connects to # 6 HT lead, is pointing towards the spark plug.
Old 05-14-2008, 04:30 AM   #133
Andy C
Andy C's Avatar
yes advances 12 degrees i asked someone else on the forum the same quesrtion micklneye
and he reckons 1 im getting so confused.
Old 05-14-2008, 05:08 AM   #134
chuh
chuh is on a distinguished road
Default how to remove the head?
I have a 91 turbo and tried once to replace the cylinder head gasket. I removed the turbo charger, intake system. removed the 14 head cylinder 10mm bolts, but the head won't come off. Used a rubber hammer to bam it from the side, but won't help. Finally, I put them all back.
Can someone tell me how to remove the head safely?
chuh is offline   Reply With Quote
Old 05-14-2008, 06:25 AM   #135
supramacist
supramacist's Avatar
Well..., the guide pins are working then. Since you're smacking it about from side to side.
You take it lose..., sounds like you have.
Means you have already locked yourself into machining it again.
Chuh..., You need to start your own thread so we can help you so bill can work in peace to get andy up and running.
And when you open your own thread. ELABORATE...., on and in. Detail.
Help us help you.
Old 05-15-2008, 04:52 PM   #136
Andy C
Andy C's Avatar
Talking yippee
ive done it! yippee sweet as a nut.
Old 05-15-2008, 06:07 PM   #137
supramacist
Congrats!!!!
But I have to say..., sweet and nut aren't words I hear dudes use everyday. Not in the same scentence,lol.
Old 05-15-2008, 06:44 PM   #138
Andy C
Andy C's Avatar
Talking wastegate.
english term mate. sweet as a nut or dogs bollo**s lol.
right now its a bit of a tidy up around the engine bay etc and start looking at the exhaust system and a couple of washes for the wastegate
do i put the washes under the bracket behind the wastegate?
still smiling
Old 05-18-2008, 09:43 PM   #139
Bill UK
AEM EMS
Bill UK's Avatar
Well Andy’s up and running again, I dare say Andy will explain the initial problem (How the hell you can fit the head up side down I don’t know) One thing I did learn from him which I didn’t realise before is that when # 1 sparks so does # 6. The 7M-GTE engine has bank of three coils, the coil on the left connects to leads 1 & 6 the middle coil connects to 3 & 4 and the right hand coil connects to 2 & 5. When # 1 sparks so does # 6, but # 6 is a wasted spark and does nothing. The same applies to the other coils they spark in pairs but one of them will be a wasted spark. Toyota in there wisdom referred to # 6 for the strobe pick up, this saves removing the coil cover that obscures # 1 lead; as they both spark together, it all makes sense now. Firing order just in case someone needs it 1-5-3-6-2-4
Old 05-19-2008, 06:09 AM   #140
supramacist
Those coil packs don't look fun to me.
They look more pricey than the standard dist cap and rotor.
Plugs and wires cost the same.
What's the life expectantsy of a new oem set of those and what do they run, american if you please.?
