Old 05-03-2008, 04:27 AM   #81
Andy C
Andy C's Avatar
thtas what i have a deep wall 12 pt socket 3/8 14mm.
doesnt fit on all of the cams get in the way
Old 05-03-2008, 11:56 AM   #82
Andy C
Andy C's Avatar
i need to tap my block as the studs arent going all the way in but i dont know what thread size is on the arp head studs i bought does anyone know what tapping tool i need please.
Old 05-03-2008, 01:15 PM   #83
Bill UK
AEM EMS
Bill UK's Avatar
Use one of your old head bolts grind 3 or 4 vertical slots in the bolt (Dremel tool cutter works well) and clean off any burrs. It can work better than a tap because: It is softer and wont remove too much metal; aswell as not being tapered it will clean out to the bottom of the hole.
Old 05-03-2008, 01:39 PM   #84
Bill UK
AEM EMS
Bill UK's Avatar
Done a bit of research Andy, It seems the extra stud length is not unusual for some reason. The threads are 12mm x 1.25 pitch.
Old 05-03-2008, 03:53 PM   #85
supramacist
supramacist's Avatar
Are you using molly?????
This seems to be more rough for you than it should be.
Old 05-03-2008, 04:42 PM   #86
Andy C
Andy C's Avatar
Smile Heads Ahead.
well the head is on now and torqued to 82.
yes used molly lube only a little though. i reckon of could of torqued them to 95 without feeling to nervous but i chickened out at 82. pleased the head is on though.
iwas just about to attach the plenum manifold but i found a swich/valve looking thing that i unbolted not sure where from think it was either under the injector rail or under the plenum maqnifold ill post a picture of it to show you guys what it looks like.
Old 05-03-2008, 09:26 PM   #87
supramacist
Some real pics may be a bit more helpfull.
Old 05-04-2008, 04:32 AM   #88
Andy C
Andy C's Avatar
can find camera lead at the moment this was all i could find. soz
Old 05-04-2008, 02:23 PM   #89
j3pz
thats a vsv. if it was near the back of the engine, its for the egr and if near the front, for the fpr
stole this from cygnusx1's tsrm page. from this pic you can see there are two vsv's, and iirc they are different so dont get them confused.
Old 05-04-2008, 05:33 PM   #90
Andy C
Andy C's Avatar
thanks for the info that really helped i now know its the front one cheers.
i havent posted many pics lately as i ve been waiting for parts.
heres a few. heads on and torqued more tommorow. ment to ba a nice day too.
the cam covers i used sand paper, hammerite smooth silver aerasol and hammerite smooth red paint.
camer up really well.
Name:	my superb supra pictures 113resizeed.jpg
ID:	1389   Click image for larger version
Name:	my superb supra pictures 114resized.jpg
ID:	1390   Click image for larger version
Name:	my superb supra pictures 115rersized.jpg
