Old 05-04-2008, 09:31 PM   #91
Bill UK
AEM EMS
Bill UK's Avatar
Nice one Andy, is that a camera lead poking out between the head and gasket in the first pic.?
Old 05-05-2008, 04:08 AM   #92
Andy C
Andy C's Avatar
sorry bill i dont know where you mean bill
Old 05-05-2008, 07:19 AM   #93
j3pz
i dont see anything in the first pic but in the third i see a wire that appears to come out of the valve cover gasket but its really the ground for the coil packs
Old 05-05-2008, 09:51 AM   #94
Andy C
Andy C's Avatar
Smile
hi people glourious day but yet again im stuck,
the 2 vsv valces i cant see where there ment to sit in the engine i ve got the wires connected except the one that comes out of the rear vsv? but can see where to bolt the actual valves to. this is the only bit i really need to do befroe i put the plenum on.
need some pics please of where they sit. many thanks guys.
Name:	my superb supra pictures 129234.jpg
ID:	1392   Click image for larger version
Name:	my superb supra pictures 1322222222.jpg
Old 05-05-2008, 12:11 PM   #95
Bill UK
AEM EMS
Bill UK's Avatar
Are these any good Andy, the red X on the bolt head is only there as a reference for each pic,
Originally Posted by Andy C View Post
can find camera lead at the moment this was all i could find. soz
Old 05-05-2008, 11:15 PM   #96
Andy C
Andy C's Avatar
thanks those pitures help a bit, the strange thing is i noticed on trsm that the vsv at the rear has a small tube coming off it leading to the 45 degree angle solid line, mine has a long piece of tubing which came from the top of the plenum.??? whys mine different?? yet again.
the trsm shows that the tubing mine goes to is incorect.
if people could give a few pics to me of this part of the car and sourrounding pictures so im can use wsome as guidance when putting everything back together. the more the merryier.
Name:	my superb supra pictures 134 fuel line vsv11.JPG
ID:	1395   Click image for larger version
Name:	my superb supra pictures 131dddeee.JPG
ID:	1396   Click image for larger version
Name:	my superb supra pictures 063ffgg.JPG
Old 05-06-2008, 12:26 AM   #97
ddmcse
ddmcse's Avatar
Cool my 2 cents
i'd replace them with new ones
they don't seem like much but they do effect the air/fuel mixture
where they bolt or hang from isn't as important
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 05-06-2008, 06:59 AM   #98
Andy C
Andy C's Avatar
here are some pics to show where my lines run to notice at the top ofthe pllenum, where ones blanked off and the other leads behind the plenum going to the vsv valvve though in the other pic of the engine(borrowed pic)
it has 2 pipes running if diffrent directions to mine?
Name:	untitl  plenumbb.jpg
ID:	1400   Click image for larger version
Name:	my superb supra pictures 069585769.JPG
ID:	1401   Click image for larger version
Name:	my superb resized vsv showhelp.JPG
Old 05-06-2008, 01:58 PM   #99
j3pz
if you look at the pic i posted before you will see that the one port blocked off would goto the bvsv on the thermostat housing (i dont know if you fellas in the uk have this, that would explain it being blocked off). as long as you have all the connections right, you dont need to use those metal lines. personally i see them as more possibilities of a vacuum leak.
edit: from your pics it looks as if someone tried to elimnate the use of the metal lines.
Old 05-06-2008, 03:47 PM   #100
Andy C
Andy C's Avatar
yeah you right cause the vsv still geos to the right place just bypassing the lines
