Old 04-21-2008, 01:02 AM   #11
NicolasDwolfwood
NicolasDwolfwood is on a distinguished road
what is the best blow off valve to run on my car i have a stock turbo
NicolasDwolfwood is offline   Reply With Quote
Old 04-21-2008, 03:24 AM   #12
Please take a little more time in the composition of your posts. It makes it a lot easier for us to accurately help and makes it less of a chore for us as well.
As for the battery, are you saying that it keeps ending up drained? If so, even if the original problem wasn't simply a bad battery, the battery is probably shot now. Check for parasitic losses when you've got a fully charged battery connected. Shouldn't be more than a few hundred milliamps of draw.
The most common replacement for the stock blow off valve for a car that's stock is a certain model Bosch bypass valve (aka blow off valve). I don't know the model myself, but you should be able to locate the specifics easily enough by searching "Bosch BOV" on most of the Supra sites.
With the power steering the problem could be any number of things. A bad power steering rack, and clogged line, a shot power steering pump, emulsified power steering fluid, or even a bad belt. For more info on trouble shooting the power steering system look here: MK3 TSRM On-Line
Old 04-24-2008, 02:59 AM   #13
NicolasDwolfwood
ok up it turn out the alternator fine, my and my brother was tinker around with th afm and next thing you know the car fired up, i took to a speed shop today he said he found oil,on the spark plugs and it was missing the gasket to prevent that, the guy said he was gonna due a complete tune up and let me know any other issues that come up
Old 04-27-2008, 12:36 PM   #14
NicolasDwolfwood
Ok here's the update, i took my car to a speed shop to get my car checked out and fixed and he found a couple of problems, one the spark plugs had oil on them due to a lack of a valve cover gasket so he had to clean it up and reseal my valve cover, and the the timing was WAY! off cause the car probably ran so bad because of the half ass build up he the former owner had to set the time off just to run the car so he set the timing back, the wiring harness is screwed up he patched it up but he suggest i get a new one. Now i need to know where can I find a place to buy a wiring harness???? beside a junk yard
Old 04-27-2008, 02:51 PM   #15
btwilson86
Super Moderator
btwilson86's Avatar
Other than Toyota, I'm not sure... But that'll be a pricey purchase there. You could look on eBay, they surface on there from time to time, but they typically will be missing a few connectors so you'd probably end up donating pieces from your current one to the "new" one you get from eBay. Other than that check the Parts Wanted/Parts for Sale part of the forum. If you have no luck anywhere, than I think you'd have to hit up the junkyard. But I'm sure someone else will chime in here that has another great place to pick one up...
Old 04-28-2008, 01:13 PM   #16
NicolasDwolfwood
kool ummm can anyone help me out to show me some pics on how it remove and install a AFM cause i have the ls400 afm in the car when i bought but its running to lean and i wanna swap the stock one back
Old 04-29-2008, 12:26 AM   #17
XxSupra-MunkyxX
XxSupra-MunkyxX's Avatar
XxSupra-MunkyxX is on a distinguished road
Default I have an often asked about problem....
My waste gate is stuck open...anyone know where the heck i can get one???!!!
I will drift and kill LS1's!!!!!!
XxSupra-MunkyxX is offline   Reply With Quote
Old 04-29-2008, 01:50 AM   #18
The wastegate or the actuator? The difference is very important.
I see you're local, I may be able to offer you a hand and I *might* have a wastegate around here somewhere.
Oh, I'm in Denver, BTW.
Old 04-29-2008, 09:59 PM   #19
NicolasDwolfwood
Ok since the speed shop i am dealing with is jerking around i need, a new mechanic i live in Queens NYC and i need a shop or a person the now how to build supra's properly i was dealing with a race shop but all he seems to be interested in me paying top dollar for parts i don't need like i am a dummy that has no idea about cars so if anyone knows anybody let me know
Old 05-08-2008, 12:12 AM   #20
XxSupra-MunkyxX
Well I need a wastegate actuator...anyone got one? I need to get my car runnin cuz the drift show is in june!!!!!
my 89 turbo auto problems twerb089 MKIII Supra 6 03-11-2008 06:26 PM
Help...Turbo Problems Supra_87_mk3 MKIII Supra 3 11-10-2007 07:51 AM
