Old 04-21-2008, 07:59 AM   #1
RspecMKiii
RspecMKiii's Avatar
RspecMKiii is on a distinguished road
Default MK3 Suspension...
I just got an 89 turbo with Eibach Pro kit springs and Tokico Illumina IIs...My buddy got an 88 turbo with the same suspension and yet the rear of my car is a bit high and my buddys is leveled...is it possible that the springs on mine have been reversed? Oh and did all MK3s come with TEMS cause mine didn't i notice my friends 88 had the TEMS light on his guage cluster and mine doesn't. Well Hopefully some one can shed some light here for me..THX in Advance >.<
RspecMKiii is offline   Reply With Quote
Old 04-21-2008, 01:15 PM   #2
Chambers
Chambers's Avatar
It is possible the spring was not seated absolutely perfect on your car or maybe the springs on your buddy's car has been on there longer so they have "worn in" so to speak.
As for TEMS, not all Supras came with it, my Supra doesn't have TEMS either.
"Stuck in the 80's"
Old 04-21-2008, 10:51 PM   #3
supramacist
supramacist's Avatar
Not all supras came with tems.
If it's not in your dash and console you don't have it.
If your front end looks awesomely low. Then ya they may have reversed them but ya, it may not have seated propperly. So take it somewhere and get it looked at. Don't drive it all janked up. You're bound to make something worse.
Old 04-22-2008, 01:33 AM   #4
RspecMKiii
RspecMKiii's Avatar
Ahh thanks for the info..i'll have that looked at right away...its a shame that mine doesn't have the TEMS cause its seems that my friends rides smoother than mine...seems like a waste to have the illumina IIs if i don't have TEMS. How hard would it be to get the TEMS set-up? Or should i replace them with a different set of shocks..any recommendations? Thanks in advanced.
Old 04-22-2008, 01:38 AM   #5
supramacist
Stick with what you have because it's probably already set to sprt mode which is where mine stays unless I'm over the road driving and then I play with it and it does make for a smoother ride.
But once you start adding sway bars..., eh. You can get by without it.
You're rigid.
Old 04-22-2008, 05:34 AM   #6
If you want a softer setup you can manually adjust the valves, I believe the details should have come on an insert with the shocks. Otherwise it should be available on their website. Nothing wrong with manually adjusting if the car is a daily driver... Plenty of owners pull the TEMS system... so you can buy most of the components and add them. It's a fair amount of work though, and you may want to find out why people don't like it first.
To check the springs just count the coils... Compare to your friends. IIRC the rears have a couple coils less.
It sounds more to me like his rear coils may be sagging or have been cut. The Eibach Pro-Kit is a raked setup... the rear sits an inch to an inch and a half higher. It is possible to exaggerate if the coil is twisted so it's not fully seated in the perch... get under and look and the perch and where the coil ends and you'll see where the coil should be resting.
variable suspension adammickeymikey MKIII Supra 3 03-14-2007 01:16 AM
have some questions about 86-92 supra suspension jeremy_e87 Non-Generation Specific Questions 2 01-10-2007 11:53 PM
A/C question - Suspension Q hobbes MKIV Supra 5 06-06-2006 12:04 AM
MKii suspension mkiiisupra88 MKII Supra 3 06-04-2006 04:01 AM
suspension question mkiiisupra88 MKIII Supra 0 05-25-2006 07:24 PM
