Old 04-24-2008, 06:29 AM   #1
ratiugslinky
ratiugslinky's Avatar
ratiugslinky is on a distinguished road
Default ignition problem???
My car wont start...sometimes. i dont know why. it turns over so its not the starter but it just doesnt start sometimes. i dont know why. im not exactly sure what to do. after i try to start it, i wait 10-20 minutes then it starts.please help! this is my first supra. anybody have any ideas?
ratiugslinky is offline   Reply With Quote
Old 04-24-2008, 02:35 PM   #2
supramacist
supramacist's Avatar
Well with the fuel injection. If you're pumping the gas to get it started you may just be flooding it out and it all has to clear out to start after the fact.
You're going to have to be more specific before we can give you any real help.
Old 04-24-2008, 05:05 PM   #3
Yeah, typically a fueling problem. Either the cold start injector isn't doing it's job while cranking or the fuel rail is loosing too much pressure at rest or the engine bay is too hot and the fuel is vaporizing in the rail.
Does this occur all the time, only when cold or only when hot?
The easiest thing to start with is pulling and cleaning the cold start injector. Is your car a turbo or N/A?
Old 04-25-2008, 12:35 AM   #4
ratiugslinky
thanks guys
Old 04-25-2008, 12:36 AM   #5
ratiugslinky
by the way it is a turbo. and it starts in the cold sometimes and the hot sometimes. i dont notice a pattern.
Old 04-25-2008, 01:58 AM   #6
Start with the CSI (cold start injector): MK3 TSRM On-Line
Old 04-25-2008, 02:04 AM   #7
supramacist
That's what I was thinking as well but didn't want propagandize bull shite.
Old 04-25-2008, 07:23 AM   #8
ratiugslinky
thanks but my engine is a 7mgte. that diagram is for a 7mge. does it matter?
Old 04-25-2008, 02:33 PM   #9
Take a look though the link I posted... it's got the info on both mixed throughout. Although, this circuit is the same from one to the next, just the locations of parts changes.
Old 04-25-2008, 03:56 PM   #10
Cool
what is the condition of the wires connected to the cam position sensor ?
wires on 20+ year old supras get dried out and brittle
if you had a cold start injector issue it would still start but it wouldn't start on the first attempt maybe the second or third
it would be interesting to check if you are getting spark to the plugs when it won't start .
i had an issue like this and it was related to mangled wires going to the CPS
Ignition Problem Burning Pyro MKIII Supra 9 04-24-2008 02:31 PM
