I'm wonder if anyone have issue with quite hot spot on tunnel next to gear box shifter /emergency break (handle is hot too) -driver site only.
thx! |
i have that problem. but it because i took off the exhaust from the crossover flange. so, all the heat rises from the exhaust right there.
....all you need is a small taste of success and you will find it suits you.... monique- better off dead ![]() |
Guest
Posts: n/a
They always run hot there. Factory setup has some heat shields under car ...on the body to keep the floor cool....above the exhaust for a ways.... Are they in place on yours??
If you look...and you're not sure...look under a friends...or somebody's. You can always make some out of sheet metal. |
i'd dont think mine has them. im not worried about it just yet, throw out bearing went out, need to fix this weekend.
87 MK III turbo - AC & Heat Always On Problem | robfab | MKII Supra | 0 | 08-04-2008 07:12 PM |
Heat Consistancy Issues | Chambers | MKIII Supra | 14 | 04-07-2008 12:52 AM |
IC pipes and heat wrap questions. | redmaro | MKIII Supra | 0 | 09-26-2007 08:00 AM |
Heat?? | burton51m | MKIII Supra | 11 | 02-25-2007 04:28 PM |
heat getting into car | sd88supra | MKIII Supra | 7 | 11-03-2006 12:47 AM |
