Old 04-27-2008, 12:53 AM   #1
3.0trd
3.0trd is on a distinguished road
Default high idle
89 na manual. I have a high idle problem. I jumped te1 and e1, timed it, (set at 10btdc) but I know with the idle being high its not timed correctly, can I manually turn down the idle?
3.0trd is offline   Reply With Quote
Old 04-27-2008, 03:41 AM   #2
You're barking up the wrong tree looking at the timing for an answer to your idle. The idle won't change due to the timing by much at all unless the timing is WAY off.
Start with the TPS.
Old 04-27-2008, 04:28 AM   #3
3.0trd
I just got the car back together after a bhg, started it, and timed it for the first time. I know the timing wouldn't be the idle issue. seems like the 7m is known for tps problems, I'll start there, thanks
Old 04-27-2008, 05:39 AM   #4
All 20yo TPS have problems. It's a wear component and should be replaced when it no longer provides stable results... the same goes for the VAF that the N/A uses to meter the air flow.
Old 04-27-2008, 03:37 PM   #5
supramacist
supramacist's Avatar
Please check out my thread "timing question".
That thread has all of your answers in it and then some.
high idle twerb089 MKIII Supra 0 06-04-2007 05:03 AM
annoying high pitch squeal at idle oowee623 MKIII Supra 2 06-04-2007 03:02 AM
'92 7MGTE- high and unstable idle liona MKIII Supra 7 02-04-2007 03:18 AM
High idle nickvash0104 MKIII Supra 21 07-13-2006 05:14 AM
