Brake Lights
The brake lights won't turn on at all whether or not im pressing on the brake pedal,all the other lights turn on...the fuses are good, the light bulbs are good,...what could be the problem?
There's a little yellow box under the driver's side taillight fixture. Pull it out, open it up and see if any of the circuit appears burnt. If it's the most common problem that little box has died. It's the Lamp Failure Module (very aptly named).
Brake lights serve as simple but important function of the vehicles. Brake lights are mainly used for warning the drivers behind when we slow down.
Light Bulb |
| All times are GMT. The time now is 12:32 PM. |
