Old 04-27-2008, 03:31 PM   #1
mkiiisupra
Default Electric Fan?
Some people say that electric fans are no good with our turbo'd cars.
Would like to put on Perma-Cool 19114 - Perma-Cool High Performance Electric Fans - summitracing.com
Rated 2950cfm and only 9.5 amps
So are the problems people have in electric fans going with cheap ones that dont pull/push enough air? Or is that simply not enough flow?
these have 5900 CFM however come with a hefty price tag lol
Perma-Cool 19513 - Perma-Cool Cool Pack Electric Fans - summitracing.com
Anyways if electric is not the way to go, any suggestions for stock fan replacement with a more lightweight set up?
1990 Toyota Supra Turbo A/T
Old 04-27-2008, 09:01 PM   #2
mkiiisupra
With this radiator / fan upgrade also doing oil cooler ... rerouting filter and changing to a dual filter also using the old oil cooler for the tranny.
As well as replace all my radiator hoses w/ steel braided lines, as well as oil and tranny lines....
Anyone ever replaced this stuff w/ steel braided lines? any suggestions, what sizes needed? How do you get them to connect to stock hook ups etc.
Old 04-28-2008, 12:20 AM   #3
SideWinderGX
holy shit, 5900 cfms with the second one...479 bucks though. if i had enough money id sell this flexalite i havent installed yet and buy that one. dont ever want my car to overheat or spin a bearing or something.
the main beef with electric fans that people have is that they supposedly dont push/pull as much air as the stock fan. noones really rated the stock fan though, and as far as i know no numbers have been produced. if going with an electric fan, id set the temp a bit lower than usual and get a good, quality fan....no cheap junk.
my car:
Old 04-28-2008, 11:00 AM   #4
Cool
i use the perma cool listed 19114 and i built a shroud around it , ok i'm using a fluidyne radiator too
i mostly cruise @ 160-170 a little chilly but thats cruising temp m 50-60 mph la la la type driving
once you start stepping on the pedals the temp adjusts .i use an electric sender temp gauge . the stock gauge sucks big time
http://www.ddmcse.com/turbo/images/SANY2150.JPG
Old 04-29-2008, 06:27 AM   #5
sd88supra
Default electric is the way to go!
It doesn't take rocket science to figure out that electrical energy can be obtained much more efficiently than mechanical energy (ok, but does take a little bit of physics). Electric fans is the way to go. It is much more efficient to power a motor via an electric current than a mechanism. Electric fans will get you more air flow with a lower energy requirement. It will take this energy from your battery instead of your gas, so be sure to have a good battery. And you don't need to be an electrical engineer to install them. The circuits are not complicated (reading instructions SOMETIMES helps).
-1987 5 spd N/A with TEMS: low miles! All stock with the exception of electric fans and an '89 front bumper, Yokohama 225/50/16 with stock rims. It's a mess and in the garage.
-1987 5 spd Turbo with TEMS: miss-matched tires, needs lots of work, but it runs! Project car.
-1988 N/A auto targa: all stock except 18" rims with Falken 265/35/18 in rear and 225/35/18 in front; daily driver.
Old 04-29-2008, 06:45 AM   #6
sd88supra
Default Puller
I forgot, set the electric fans to pull. More are flows as a puller than a pusher. Or you can have one and one. I think the problem with people is that they don't set the fan so it blows air in the right direction!
Pusher Radiador Puller
-----> == -----> to engine
Old 04-29-2008, 06:46 AM   #7
sd88supra
^that didn't come out right, but you get the idea.
Old 04-29-2008, 08:29 AM   #8
carfanatic89
carfanatic89's Avatar
Oh by the way, 6 of one half dozen of the other, your battery doesn't just make voltage, its supplied from the alt. and that gets its energy from the crank and the rod to the piston taking power and gas milage. It would probably be more efficient but still pull power and gas milage from the motor
Supra Engine Powered Dragster
Old 04-29-2008, 11:35 PM   #9
sd88supra
Yes, but the energy the alternator needs to resupply voltage in the battery is much lower than the energy required to operate the fan clutch. Gas mileage difference is hardly noticeable if at all, but cooling efficiency is what we're after. I was referring to the battery because a 30 ampere fan can easily drain a crappy battery.
Old 04-30-2008, 11:47 AM   #10
mkiiisupra
are your saying i need 2 fans? one in front and one in back of radiator?
Electric Fan Controller Temp. question SilenceboneSupra MKIII Supra 19 06-16-2010 08:27 PM
Pulling ICE and related parts and GOING ELECTRIC ddmcse MKIII Supra 6 12-11-2008 09:40 PM
Help on electric seat supratrd654 Non-Generation Specific Questions 1 03-14-2005 07:12 AM
Help!!! looking for electric seat diagram supratrd654 MKIII Supra 0 03-08-2005 03:17 PM
