Old 04-28-2008, 07:16 AM   #1
azerty
azerty's Avatar
azerty is on a distinguished road
Default Aluminium piping. Is it a mistake or not?
Hi all.
I saw many replacing the plastic ducts in their cars with aluminium ones. Hell, I one of them .
But than I read somewhere that the metal is a conductor of heat, and the plastic (the compound from with the piping are made) is heat insulated.
So is it or is it not a good ideea to replace the plastic pipes with aluminium ones?
Are the aluminium pipes going to transfer the heat to the intake air and by doing so to reduce the performance of our engines?
What do you think?
1988 yelow manual turbo targa
HKS ssqv bov
Hose Techniques silicon hoses
Forge manual boost controller
boost gauge
K&N FIPK
ACT clutch kit HD-G6
Fidanza lightened flyweel
550cc RC Injectors
255lph Walbro Fuel Pump
LIPP Lexus AFM Replica
3" turbo back echaust with divorced
downpipe and no cats.
Aeromotive FPR
Aem Uego Wideband Gauge+O2 sensor
azerty is offline   Reply With Quote
Old 04-28-2008, 12:35 PM   #2
ddmcse
ddmcse's Avatar
Cool
thats way you want to get a front facing throttle and intake setup to avoid running the intake right over the engine
http://www.supra.co.nz/ffi/ffi1.jpg
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 04-28-2008, 03:20 PM   #3
h8z2luze
h8z2luze's Avatar
h8z2luze is on a distinguished road
Do they make those for the 7MGE or just the 7MGTE?
1989 Supra 7MGE MK3 5-speed project...
http://www.cardomain.com/ride/2385505
h8z2luze is offline   Reply With Quote
Old 04-28-2008, 03:36 PM   #4
azerty
azerty's Avatar
Man... don't get me wrong...
It is easier to put the plastic back than to change the position of the engine...
HKS ssqv bov
boost gauge
K&N FIPK
550cc RC Injectors
Aeromotive FPR
Old 04-28-2008, 04:00 PM   #5
azerty
azerty's Avatar
Sorry, but I don't know...
But hey, you can ask them
Here's 1 site seling this stuff. I am sure youfll easely find others.
www.suprasport.com
HKS ssqv bov
boost gauge
K&N FIPK
550cc RC Injectors
Aeromotive FPR
Old 04-28-2008, 06:28 PM   #6
A FFIM on a 7M-GE may not work well. You'll loose the ACIS which helps level out the power band a significant amount and give you more power on the low end.
Yes, the metal does soak up heat quite readily. If you're doing a lot of city driving it may not be worth it. At idle my N/A's intake temps climb as much as 20?F. How quickly those temps drop once the car is moving again depends on how much I get on the throttle, but it takes a few seconds. I'm planning on adding a fiberglass sleeve to insulate it.
I really can't say I recommend removing the resonator... but to understand that you would actually have to research it and learn how it works... so do as you will.
Old 04-28-2008, 11:43 PM   #7
h8z2luze
h8z2luze's Avatar
Whats ACIS???
Old 04-29-2008, 01:57 AM   #8
Forerunner to V-Tec and VVT-i. The manifold is designed in such a way that a large butterfly valve in the surge tank can be used to emulate long or short runners as needed. Without it your power below 4000RPM takes a hit. MKIII and MKIV N/A's both have this system. Other 7M-GE equipped engines (such as that from the Cressida) do not have it and it's part of the reason they make less power.
EDIT: You could of course go with a completely custom FFIM with multiple runners and valving such as the manifolds BMW used with a couple of their newer inline 6's... you're going to need one hell of a crew to help you calculate and cut everything to the precise lengths needed though... If you tipped the engine a decent amount you could build something similar to the old BMW manifolds, but it'll have to be tipped further to still accommodate the stock ACIS valving. BMW M3
Old 04-30-2008, 12:44 PM   #9
mkiiisupra
After a long drive down the highway i can stick my hand on my cooleeze pipes where it runs over engine bay and its cool to the touch, not cold but ya kno what i mean.... I can also lay my hand on the intake penlum which is only slightly warm....
Before i changed the pipes i couldnt touch the 3000pipe or the intake penlum..... was much to hot
1990 Toyota Supra Turbo A/T
Old 04-30-2008, 12:54 PM   #10
mkiiisupra
All my pipes are ceramic coated though
Intercooler piping mr.w MKIII Supra 6 12-13-2006 12:34 AM
Intake Piping/ IC Piping Supra2NR MKIII Supra 4 11-16-2006 03:12 AM
hard piping skunk MKIII Supra 3 10-26-2005 01:36 AM
