Old 05-27-2008, 12:46 AM   #61
supramacist
supramacist's Avatar
I had 1 thing go wrong and by the time I finished poking and prodding I have a list now.
It never ever seems to fail.
These cars cover up so well until they break.
Old 05-27-2008, 02:47 PM   #62
blackturbo1
blackturbo1 is on a distinguished road
Default you-tube engine knock
OK, my next two cents goes toward a cam follower knock, that is, the knock sounds to me like it's coming from the head, not the block. Although it's not easy to diagnose from a video and because I don't know exactly what yours sounds like, I can't say %100 that this is the cause but if I were to bet, I would say it definately sounds like something in the head.
Since Supra cam followers are solid type and not hydraulic, only two possibilities arise, either there is too much clearence between the cam lobe and the follower or you may have a valve that is slightly sticking. If the valve is sticking you could try some marvel mystery oil. If clearance is the issue, you've either got a worn cam lobe or follower shim or a combination of two.
Of course, I could be totally wrong and you might have a bad piston pin.
In that case, time for a new motor.
blackturbo1 is offline   Reply With Quote
Old 05-28-2008, 04:43 AM   #63
spudz29212MKIII
spudz29212MKIII's Avatar
spudz29212MKIII is on a distinguished road
its in the head, i know that, loudest at exhaust side valve cover
Zach
spudz29212MKIII is offline   Reply With Quote
Old 05-29-2008, 06:48 PM   #64
walshy2103
walshy2103's Avatar
walshy2103 is on a distinguished road
Default Help
Hi, can anybody help me please? ive recently blown up the engine (7MGTE) in my supra and replaced it with an other. Everything is fine apart from i have not got a spark. I broke the reverse speed sensor off the gearbox (have not got a clue what the reverse speed sensor does??) does it have anything to do with the spark? the ignitors should be grand because they were not touched. Could somebody point me in the right direction?? thanks
walshy2103 is offline   Reply With Quote
Old 05-30-2008, 04:34 AM   #65
spudz29212MKIII
Ran a EFI Diagnosis?
Zach
Old 05-30-2008, 06:44 PM   #66
supramacist
The ignitors should be grand says: you haven't checked them yet.
Please do.
