Old 04-30-2008, 12:34 PM   #1
jdpartridge05
jdpartridge05 is on a distinguished road
Default Problems
ok this is what i got its a 87 7m-gte 5sp. this is whats goin wrong. i was boostin at like 5500rpms at 10psi in first. then i slowed down and i heard a noise like a loud whistle. then the car shut off. i started it again and it whines really loud, wont go over 1500rpm, runs rough, also smokin from the exhaust. thanks for any help
jdpartridge05 is offline   Reply With Quote
Old 04-30-2008, 06:06 PM   #2
Ouch... well, start with checking for error codes:
Cygnus X1 Home Page
Old 04-30-2008, 08:20 PM   #3
SideWinderGX
check all the hoses near the turbo, hopefully an IC hose or vacuum hose(s) popped off that are making it run like crap. it could be that the turbo crapped itself too you hear a 'death whine' when its spooling up if its bad.
my car:
Old 05-02-2008, 04:18 PM   #4
jdpartridge05
I/C pipe was disconnected well.....blown apart. thakns for help
Old 05-03-2008, 03:47 AM   #5
spudz29212MKIII
spudz29212MKIII's Avatar
My god why were you boosting 10lbs at 5500 in first gear...you have big kahoonas...I would be scared my car would explode. Cause in first the most powerful gear boosting 10lbs then letting off...im having bad visuals
Zach
Old 05-03-2008, 12:37 PM   #6
jdpartridge05
10k on rebuilt bottom end, je pistons, eagle rods? should hold up
