-   -   second gear grind (http://www.toyota-supra.info/forums/mkiii-supra/11329-second-gear-grind.html)
supramacist 05-12-2008 03:32 AM
Originally Posted by CyFi6 (Post 58521)
bleed your clutch. It could be that your second gear synchro doesn't work as well as the others, therefore it is the only one grinding, but your clutch may still be grabbing slightly when disengage it because of air in the line.
This is a good point as well.
I still push for the flush and fill though.
I have seen that alone almost work miracles in many different cases.
