Old 05-08-2008, 01:31 AM   #1
csk239
csk239 is on a distinguished road
Default 91 NA water pump
i may be getting a supra NA and needs a waterpump i was wondering if the water pump runs on the timing belt or on the alt. belt like my 86 mr2 does?
and is it easy to install?
csk239 is offline   Reply With Quote
Old 05-08-2008, 01:38 AM   #2
supramacist
supramacist's Avatar
Hello and welcome.
I have a 91 n/a as your luck would have it.
The water pump runs on the alternator belt.
It's not bad. Let's say 1 to 10.
Maybe a 2.
Why do you think you need a new water pump? If I may ask.
Old 05-08-2008, 01:41 AM   #3
csk239
the guy said that it needed one...im goin to go look at it tom.:-) if its the waterpump and its on the alt. belt then it should be alot easier then on my mr2 haha...thanks for your help
Old 05-08-2008, 01:44 AM   #4
supramacist
The water pump shucking could be a sign of larger issues abound.
Glad to help.
Old 05-08-2008, 01:48 AM   #5
csk239
like the head gasket? what kind of trouble would that be?
Old 05-08-2008, 01:54 AM   #6
supramacist
Yes the head gasket.
Old 05-08-2008, 02:12 PM   #7
mrnickleye
mrnickleye's Avatar
Yes........many sellers tell people the problem with the engine is a pump, or thermostat, or radiator, which they all may be bad.........but the real problem is the BHG.
And......every 7m motor in the world will have a BHG at some point in time.
Unless the car is really cheap, like $500, I would never buy one that I could not take for a test drive for about 30 minutes to see how things are.
And for other people, I tell them to have their mechanic look over the entire car and estimate all the repairs it will need so you can drive it every day.
Old 05-08-2008, 04:05 PM   #8
supramacist
Ya it's a trap.
If you haven't researched deeply into this make and model your novice eyes can't see as they should.
Mine couldn't and this is the 3rd summer of my build.
She's finally running and sounding strong. Even though I have done all that I can. I am sure the car is nowhere near the original stock rating of 200hp.
But is significantly stronger. I'm not looking for hp #'s anyhow.
Just a fun car to drive.
You aren't the 1st and you aren't the last.
Old 05-09-2008, 08:21 AM   #9
csk239
thanks guys really big help almost fell into it...i think im going to stick with my aw11!
Flowrate of the Stock Water Pump? Bolarbag MKIV Supra 5 06-03-2008 09:26 PM
Water Pump!!! IHateHacks MKIII Supra 10 05-16-2007 04:44 PM
Bad Water Pump? scruffboy Non-Generation Specific Questions 10 11-26-2006 04:37 PM
Replace Water Pump? Benesesso MKIII Supra 3 03-31-2006 12:26 AM
1gte water pump streetbeast MKIII Supra 15 06-24-2005 08:02 PM
