Old 04-16-2008, 04:11 AM   #1
marc
Default TPS problem
well my TPS has never been right since i put my supra back together. No matter where i put the sensor i can never get idle right, even when adjusting the idle screw. And also it feels like its cutting at like 4000 rpm. The car will keep reving up and the boost will peg out, but the speed will drop as if the fuel is being cut. I ran codes and got a TPS trouble code
nothing but the best
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
4 washers on the wastegate
highflow cat
short shifter
many more upgrades soon
Old 04-16-2008, 10:32 AM   #2
ddmcse
ddmcse's Avatar
Cool
did you screw up one of the four wires connecting the tps ?
i'd get the screw back to were it belongs and then work on the timing .
i think it's an art to get that sucker in there just right
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 04-18-2008, 12:23 AM   #3
marc
i dont know where the tps screw originally was. and there only 1 wire connecting the tps
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
highflow cat
short shifter
Old 04-18-2008, 04:36 AM   #4
btwilson86
Super Moderator
btwilson86's Avatar
Your TPS should have 1 connector with 4 wires coming from it... If not, then that would be the first clue as to why you have the Tps code.
Old 04-30-2008, 03:07 AM   #5
marc
nah it has to do with where the TPS is situated. how od i properly set the tps?
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
highflow cat
short shifter
Old 04-30-2008, 03:19 AM   #6
TPS testing info: MK3 TSRM On-Line
The alignment info is two pages later, test it first the TPS is a wear component.
Why do people have to keep screwing with the "idle screw"? It's a modern car! The idle is computer controlled! So unless you've already moved it, odds are it's right where it needs to be... which in this case, yes, I know, you've moved it.
Old 05-10-2008, 09:10 PM   #7
marc
ok well what the manual fails to show is how the tps shuld be put on. should it go on, so that when i turn it, the throttle gives no resistance? or should it be if i turn the tps the throttle opens a little bit? a fast replay would be appreciated seeing as i have the TB in my hand and i need this thing together lol
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
highflow cat
short shifter
Old 05-10-2008, 10:13 PM   #8
supramacist
supramacist's Avatar
The tps can really only go on my 91, One way.
Put the throttle body on and the rest should be easy to figure out if you take your time and look at it for a bit.
My general rule of thumb: Think 5 times. Wrench once.
Does this always work you ask??? It helps alot.
Do you need a vac. hose diagram?
Vacuum Piping
All the answers you need are inside the tsrm that CRE gave you, a few posts back.
Save it to favorites and dig deeper.
ABS Problem? rasclaat_98 MKIII Supra 6 12-13-2010 09:53 PM
found the problem brs86supra MKIII Supra 0 05-02-2006 03:42 PM
Boost Problem, I Guess nonstop213 MKIII Supra 0 02-23-2006 07:32 PM
tsp problem for na t supra jdlee123 MKIV Supra 0 09-02-2005 06:01 PM
