Old 05-14-2008, 03:56 PM   #11
supramacist
supramacist's Avatar
Would an air / fuel meter work on an na?
I mean..., I'm sure it would but, how effective would it be?
I ask because I hadn't thought about that.
We n/a's don't have some of the same headaches.
Old 05-14-2008, 08:24 PM   #12
mc_p0pe
mc_p0pe is on a distinguished road
Well, right before i bought the car last summer they had the head gaskets replaced and a new fuel pressure regulator put in... not to mention they hooked up the wrong vaccuum hoses to it and i had to sort it out, but do you think this could be the cause? a cheap fuel regulator...
and i already have a air/fuel gauge
mc_p0pe is offline   Reply With Quote
Old 05-14-2008, 08:30 PM   #13
supramacist
1. I don't condone using cheap parts.
I think we as a collective should strive to use quallity parts to uphold the heritage that is supra.
Just to clear the air. I would only use a cheap one to see if it helps.
That way..., it's only a 20$ if. That you can assuredly return.
Will it aid in running rich? It will certainly monitor the fuel pressure so you can cut it back to make it run "not" so rich.
This is the theory I am operating on.
If I am wrong..., Please correct me. Feel Free.
I'm here to learn as well.
Old 05-23-2008, 12:31 AM   #14
supraflymk3
supraflymk3 is on a distinguished road
my supra has the same issue except mine is stock.
supraflymk3 is offline   Reply With Quote
Running Sooooooo Rich! Help! godgaveussid MKIII Supra 4 08-29-2007 08:46 PM
Running very rich OmeGa MKIII Supra 3 12-09-2006 09:59 PM
Running rich! grygst76 MKIII Supra 6 09-29-2006 01:56 AM
fuel running very rich famous Non-Generation Specific Questions 8 08-17-2006 01:49 PM
fixed the running rich problem djalkyd MKIII Supra 6 05-04-2006 04:31 AM
