Old 05-15-2008, 12:52 PM   #1
Andy C
Andy C's Avatar
Default timing yet again
ive timed the car on ht 1 yet it still has doesnt seem timed, i was told to time on number 6 but gave up on this idea as i cant do it.
the revs arent smooth and after driving for more than 20 secs it gets worse? any ideas folks
Old 05-21-2008, 06:24 AM   #2
Make sure the timing belt is on correctly. Then the cam sensor.
Old 07-03-2008, 09:33 PM   #3
toneloc87 2
toneloc87 2's Avatar
toneloc87 2 is on a distinguished road
does the tensioner adjust itself or do you need a certain tool to get it to work and how should the belt be placed on the cam gears?
toneloc87 2 is offline   Reply With Quote
Old 07-03-2008, 09:50 PM   #4
robertsws
robertsws's Avatar
robertsws is on a distinguished road
the 7m gte engine is timed by using the #6 wire
the 7m ge engine is timed by using the #1 wire
why can't you get to the #6 wire? i just timed mine and it was simple even though i've still got the 3000 pipe and all that straddleing the engine.
1991 Supra - Turbo - 5spd
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
550cc injectors (2 sets, venom direct fit, RC engineering)
2.5" intercooler and piping
Aluminum radiator w/dual electric fans
ARP bolts w/MHG
Full-auto turbo timer
Fidanza Flywheel & Stage 2 Clutch
spark plugs and wires.
power steering pump
cold temp start switch
engine top end rebuilt
transmission opened up and inspected at a tranny shop when the flywheel and clutch installed last week.
robertsws is offline   Reply With Quote
Old 07-05-2008, 08:43 PM   #5
supramacist
supramacist's Avatar
All of this is in the tsrm. If you don't have a copy let someone know and we"ll send you a link. We hand that stuff out like candy around here.
Old 07-05-2008, 11:01 PM   #6
toneloc87 2
ya i printed it all out lol but i cant seem to figure this out.
Old 07-06-2008, 04:59 AM   #7
mkiiisupra
I was reading through the TSRM in the timing instructions and it does not mention a specific wire to use. Where did you find this information?
1990 Toyota Supra Turbo A/T
Old 07-06-2008, 08:58 AM   #8
f00g00
http://www.turboninjas.com/mk3supra/...Mechanical.pdf
Page EM-17
Step 2
NOTE at the bottom of step 2
Old 07-06-2008, 10:00 AM   #9
Bill UK
AEM EMS
Bill UK's Avatar
When # 1 sparks so does # 6. The 7M-GTE engine has bank of three coils, the coil on the left connects to leads 1 & 6 the middle coil connects to 3 & 4 and the right hand coil connects to 2 & 5. When # 1 sparks so does # 6, but # 6 is a wasted spark and does nothing. The same applies to the other coils they spark in pairs but one of them will be a wasted spark. Toyota in there wisdom referred to # 6 for the strobe pick up, this saves removing the coil cover that obscures # 1 lead; as they both spark together, it all makes sense now. Firing order just in case someone needs it 1-5-3-6-2-4
advanced timing? sd88supra MKIII Supra 7 04-27-2008 03:44 PM
Photos of my timing belt Nato99 MKIII Supra 7 08-27-2007 09:33 PM
Can't adjust timing... Lunch2000 MKIII Supra 7 11-26-2006 04:09 AM
timing issues stuck1 MKIII Supra 0 03-27-2006 02:16 PM
setting timing on a GTE djalkyd MKIII Supra 0 03-19-2006 04:39 AM
