Old 05-02-2008, 07:40 PM   #1
Fredde
Fredde is on a distinguished road
Default Supra wont start.
Hi, i?m new to supras and i have a problem with it.
When i turn the ignition key, all that happens is a click from the trunk or somewhere around that area. The starter/solenoid does?nt sound.
My antitheft system seams to be dead. I want to remove it but dont know how to remove the carpet without damaging anything.
You will have to excuse me for my crappy english, im from sweden.
/Fredde
Fredde is offline   Reply With Quote
Old 05-06-2008, 02:13 AM   #2
ratiugslinky
ratiugslinky's Avatar
ratiugslinky is on a distinguished road
it sounds just like the starter. is it a 5 or 6 speed? if it is then try roll and jump start. then it sound like its your starter.
ratiugslinky is offline   Reply With Quote
Old 05-06-2008, 02:19 AM   #3
SideWinderGX
SideWinderGX is on a distinguished road
try to start it in another hour. if it works, post back here...its the wire going to the starter.
if it doesnt, and it doesnt work at all over the next day or so, you can either push start it like ratiug said, or its your starter/solenoid.
my car:
1987 brownish Toyota Supra Turbo, automatic 7MGTE engine with ~100k miles on it.
SideWinderGX is offline   Reply With Quote
Old 05-06-2008, 12:14 PM   #4
Fredde
hi.
I?ve discovered that the original anti theft system is disabled, someone has put an aftermarket Gemini alarm in it. Wich ofcourse doesnt work at all. I took the covers under the dash off becouse i thought i could see where the alarm cuts ignition and fuel but no succes.
I managed to get the starter going, so now the enginge cranks. But no spark or fuel. The other cables is just hooked on to a few cables, i cant figure this out.
Can i get the fuelsystem and ignition system powered just to see that it fires up? It would be perfect to feed ignition/fuel straight from the battery with 2 hidden switches somewhere.
I would be really happy if anyone can help me solve this!
/Fredrik
Old 05-07-2008, 09:23 AM   #5
f00g00
Check your fusible links in the fuse box on the left hand side of the engine compartment behind the battery. The 30A provides power to the EFI and IGN systems, and check the EFI fuse there also, the IGN fuse is in the left kick panel.
Old 05-07-2008, 02:22 PM   #6
Fredde
Would it be possible to feed the efi/ign with power from those locations?
/Fredrik
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
Supra wont start Micahwc MKIII Supra 1 03-14-2008 05:57 AM
Supra won't start cmnetworx MKII Supra 2 07-31-2006 10:55 PM
supra wont start tex1116 MKIII Supra 2 10-21-2005 12:54 AM
