Old 05-20-2008, 09:09 PM   #1
spudz29212MKIII
spudz29212MKIII's Avatar
Default Prop/Drive Shaft, brake question
I replaced front rotors and pads, little bubbles in the lines but we bled it. When I am coast'n down a hill in idle I can still hear the front brakes drag at a certain point. And it gets worst when going around a curve.
Ya'll think air might still be in the lines, or could I have a wheel bearing bad? Up on the lift the tires did not move barely at all when you move top, bottom back to forth.
Next inquire;
Well when we had the car up on the lift I was just checking around and came upon the propeller shaft. (note; no weight on any tires or suspension) When I put my hands on either side of the center bearing I could lift the shaft up and down like a 1/2 in to an inch.
Is that normal? I thought the shaft should not move at all if its bolted to axel and tranny (even if its a two piece). New center bearing?
Also, info why I think its bad; car still has little vibration on highway speeds, and some times a really rough shift when tranny engages like a big clunk sound. Almost like the shaft is jumping up at the bearing. The support braket looks like it has taken some twisting stress.
Thanks guys
Zach
Old 05-21-2008, 12:35 AM   #2
supramacist
supramacist's Avatar
Drive shaft slap?
Maybe a carrier bearing.
Old 05-21-2008, 02:51 AM   #3
spudz29212MKIII
yea pretty much a body slap..
whats a carrier bearing? didnt see it in the TSRM
Zach
Old 05-21-2008, 04:41 AM   #4
supramacist
The carrier bearing is the main drive shaft bearing.
It sounds like play in your driveshaft.
Old 05-21-2008, 05:06 AM   #5
spudz29212MKIII
yea def plays too much. Why is the shaft in two pieces anyways?
Which is a better idea, replace the bearing or just get a new complete shaft?
Any ideas on the brakes?
Zach
Old 05-21-2008, 05:16 AM   #6
supramacist
Brakes: toyota oem rebuild kits for the front and back via your dealership.
Drivetrain: Niether one of those are inexpensive to replace dude.
Carrier bearings are priced sky high. A drive shaft could cost you a grand.
U-joints. I like to use spicer, but I haven't changed mine out yet either.
The good news is that with ramps and jack stands you can do all of the work yourself. Easily within a weekend.
I'm not totally sure what you have but you sound like this could be it and it just happens in autos such as vans and 3/4 ton trucks from the drive train hauling that weight. In your case it's probably there from years of negligence.
If I had to venture a guess. I would say the carrier bearing is close to $250/$300. And the other 2 u joints are going to run anywhere from $75 / $125.
If you have never ''wrestled'' u-joints before. You had better study up.
They can be a real pita unless someone knows the trick.
I have long since forgotten it, without some hands on.
I hope this helps, man.
Crank Shaft Pully Question kidsusukigsxr Non-Generation Specific Questions 1 04-15-2011 08:45 PM
Brake question suprabahamut MKIII Supra 4 08-13-2008 05:32 AM
anti-lock brake system abs question linuxgurupodboy Non-Generation Specific Questions 0 09-30-2007 03:06 AM
question on removing crank shaft kidsusukigsxr Non-Generation Specific Questions 12 07-07-2007 03:49 PM
brake question damdog05 MKIII Supra 13 07-18-2006 04:01 AM
