Old 06-04-2008, 12:23 AM   #1
JPJ
JPJ is on a distinguished road
Default Oil inside CPS.
Is this likely caused by a worn o ring or something.
I've yanked the sucker out, and I don't see one.
Any help is greatly appreciated.
JPJ is offline   Reply With Quote
Old 06-04-2008, 04:30 AM   #2
supramacist
supramacist's Avatar
Dig deeper the shaft that inserts into the head has a seal inside the dizzy.
You have to remove some things and drill some bolts to remove the gearing at the end of the shaft to remove it from the dizzy.
Once it's out you can see the gasket on the inside. This can be done by you but requires surgical precision which may not be obtained in many the back yard garage, without precaution.
Old 06-04-2008, 09:14 PM   #3
JPJ
thanks bro, I appreciate your reply.
I found this.
Can you tell me what would prompt this proceedure?
MK3 TSRM On-Line
I mean, why would that gear ever need replacing?
Old 06-05-2008, 12:44 AM   #4
supramacist
I have never done this to my car.
So This may not be 100%.
I believe the gear has to come off from what I have read to get the shaft removed from the dizzy. That seal is a wear item.
Someone was saying you can get an entire beck arnley dizzy for like 50$ from autozone. I don't know because I don't use that supplier. Point of fact. AZ is the last place I check and only in times of dire straights.
Glad I could help. Hope this helps.
Old 06-05-2008, 04:24 AM   #5
mrnickleye
mrnickleye's Avatar
Wink All About the FAQs
I shall now take a moment to chastise JPJ for not checking in the FAQs section for the answer to his problem.
And let us ALL be reminded to do so from now on. It may not have all your answers, but it has a whole bunch.
OK, so the answer to you troubles is.............
kbox Engineering
I bought it, and the company, and the parts they sell, is top notch.
Tah Tah for now.
Old 06-05-2008, 01:35 PM   #6
JPJ
kbox Engineering
Tah Tah for now.
Thanks friend.
purcashing 1987 toyota supra soon, YAY! HG questions inside. SideWinderGX MKIII Supra 21 02-07-2007 02:55 AM
Having some idle problems...please help, details inside noredline MKIII Supra 6 09-18-2006 11:38 AM
What does this light mean? pic inside Sharaz508 MKIII Supra 6 06-09-2006 05:17 AM
trunk not opening from inside burton51m MKIII Supra 2 05-13-2006 05:42 AM
water leaking from A/C inside car Ron90Turbo MKIII Supra 2 09-12-2005 04:31 AM
