Old 06-06-2008, 12:10 AM   #1
TomFraser
TomFraser is on a distinguished road
Default I will be buying a 1988 N/A supra in 2 days, 1 question
1988 Toyota Supra
this car is amazingly clean, and 100 percent stock, saturday I will be testing the compression of the cylinders, if those are fine then I will be driving it home.
BTW: where can the fuse for the fuel pump be found? that way when cranking there will be no gas going to engine.
If the compression is fine should I retorque the head to the proper amount (to prevent it from going bad), or let it be?
I have read that if it is that old and has sat like that fine for 20 years that adjusting it might encourage it to go bad.
What do people think... is this an opinion thing, or was someone misinformed?
Thanks so much for help!
EDIT: Also what fluids/hoses/belts should I be replacing as a priority?
TomFraser is offline   Reply With Quote
Old 06-06-2008, 02:16 AM   #2
CyFi6
you can pull the EFI relay which is located in the fuse box under the hood, on the drivers side. That will disable fuel for you. Things you will want to do right off the bat
Oil change-for sure
coolant- for sure
power steering- would be a good idea
tranny fluid- would be a good idea. Use Redline MT-90
Diff fluid- would be a good idea.
Brake fluid- a must if its looking old or dark
check brakes for wear
Check all suspension components and replace as necessary
You might want to ask when and where the head gasket has been changed if they are the orig owners. With 185k miles i am assuming it has blown the head gasket sometime in its life, and if it hasn't, i would be prepared for it to come along soon.
Also: Lift up the wood panel in the trunk and look in the spare tire well, where it sits. This is a spot known to accumulate water from leaky hatch seals and get rusted out.
Old 06-06-2008, 12:45 PM   #3
TomFraser
Oil change-for sure
coolant- for sure
so should I retorque the head to prevent the headgasket from blowing, or should I let it be as it has lasted so long already?
Thanks for the reply
Old 06-06-2008, 02:39 PM   #4
CyFi6
I honestly don't know so i don't want to give you incorrect info, but from what i have read it seems to be pretty well debated and people have different opinions. I don't think i would do it personally, but that is just me.
Old 06-06-2008, 05:06 PM   #5
dj7mge
dj7mge is on a distinguished road
if the headgasket wasnt replaced i would just change all the fluids and drive the car really easy dont rev it high or anything untill you have some $ saved up to replace it. It's a pretty costly job i spent $1,200 and thats with a employee discount working at a toyota delership but i also replaced all the belts gaskets water pump ect.
dj7mge is offline   Reply With Quote
Old 06-06-2008, 06:08 PM   #6
TomFraser
Thanks for the opinions... I think I am going to let it be until it breaks... Thanks for the replies and I'll be sure to post pics!
buying a supra docvtak MKIV Supra 6 11-16-2005 01:29 PM
1993 Supra Sport Roof buying Question SupraDank420 Non-Generation Specific Questions 1 06-07-2005 01:51 AM
