Old 06-12-2008, 01:22 AM   #1
supraflymk3
supraflymk3 is on a distinguished road
Default Gas Gauge broken
don't know what wrong with it any help??
supraflymk3 is offline   Reply With Quote
Old 06-12-2008, 01:40 AM   #2
Chambers
Chambers's Avatar
I'm not sure if there is a fuse for it but thats where I would look first, a good friend of mine in his Rodeo took two weeks of hard work and waiting for parts to get his tank down, get the old sending unit out, put the new unit in, and finally getting the tank back up. In the end it was just a fuse that blew.
If that comes to no avail, then I think you can get to the sending unit through the hatch. I haven't had to do anything with the fuel tank in my car so far so I'm not so sure if you can get to it through there.
Hope this helps, good luck!
Edit:
The TSRM says to drop the tank to access the fuel pump, so I guess you will have to drop the tank if you need to replace the sending unit.
"Stuck in the 80's"
Old 06-12-2008, 01:57 AM   #3
supramacist
supramacist's Avatar
Jesus these cars never stop breaking.
I'm either going to fix mine and sell it. Or part this thing out.
It's such a never ending process and when you think you're almost finished.
KABOOM. Square 1. For the umpteenth time.
Old 06-12-2008, 03:06 AM   #4
CyFi6
The sending unit is separate from the fuel pump! There is an access panel for it under the trunk floor and you can remove the entire thing and test it and even fix it without dropping the tank! There is an article on fixing an inconsistent gas gauge on sogi.
Old 06-12-2008, 01:20 PM   #5
Chambers
Chambers's Avatar
Ahh, sorry for the miss info.
"Stuck in the 80's"
Old 06-12-2008, 07:54 PM   #6
supraflymk3
oh thanks yeah i fixed it somehow my wires got loose i guess. but yeah it works now! thanks!
Old 06-12-2008, 09:08 PM   #7
Bill UK
AEM EMS
Bill UK's Avatar
Yep! you can say that again supramacist my head gasket has just gone, this will be my fourth BHG on four different supras, Ok I've had supra`s for 22 years, probably clocked over 350,000 miles if you include all of them, not a bad average I suppose. Still well pissed off though.
Old 06-13-2008, 04:39 AM   #8
supramacist
<<<< fed up .
Still I refuse to throw in the towel.
The car is just too damn cool.
I'm looking at new jcw 208hp mini cooper.
Petrol Gauge Sender Supra Mk3 supra mk3 brunei MKIII Supra 0 02-17-2008 04:14 PM
Gauge cluster dcrusupra MKIII Supra 2 11-16-2005 11:55 PM
