Old 06-12-2008, 11:26 PM   #1
Chambers
Chambers's Avatar
Question Rear Differential Clunking
Hi all, I think the rear diff in my car is toast. It has a lot of play, but the weird thing is its not dead play, I can turn the drive shaft about a quarter turn and during the turn both of the CV shafts turn at the same rate as I'm turning the drive shaft. When I drive the car it sounds like a ka-thunk sometimes and other times it sounds like a ping, such as when u-joints go bad. I haven't had a chance to check the fluid, but I will shortly.
I think its time for a re-build, if possible. So I have a few questions;
Where can I find the gear ratio, is it on the diff or somewhere else?
Has anyone done any work to the non limited slip diffs before?
Where besides the dealership could I look for a rebuild kit?
Thanks!
"Stuck in the 80's"
Old 06-13-2008, 09:25 AM   #2
SimpleSauce
SimpleSauce is on a distinguished road
I have the same problem as you. Someone help us out. I'm gonna try to change my fluid this weekend.
SimpleSauce is offline   Reply With Quote
rear differential bolts aaron_arthur Non-Generation Specific Questions 0 07-16-2008 03:34 AM
Clunking in rear? FunWheelDrive MKIII Supra 8 02-28-2008 08:35 PM
Rear differential question finaltable MKIII Supra 9 11-13-2007 07:49 PM
Supra rear differential 87supraguy MKIII Supra 4 04-18-2005 07:05 AM
