Old 01-18-2009, 09:10 AM   #11
CyFi6
did you have the rotors turned?
Old 01-18-2009, 09:28 AM   #12
Serge
Serge is on a distinguished road
no I did not. I would say that vibration almost doen't exist when I push my brakes...
Serge is offline   Reply With Quote
Old 01-18-2009, 09:30 AM   #13
CyFi6
They get glazed though, always worth it to get them turned or replaced, wouldnt be a bad idea to still do it
Old 01-18-2009, 09:34 AM   #14
Serge
OK...it sounds like a bearing but I'm not sure about that.....the car has 112000 miles only...
Old 01-18-2009, 11:09 AM   #15
Busted Knuckles
Busted Knuckles's Avatar
Did the shims also include spring clips? These clips (2) go into those little holes on top of the pads, look something like wishbones, and work to separate the pad from the rotor when the pressure is off. This also helps eliminate squeaks.
To check the hub bearing, refer to the MK3 TSRM On-Line
Old 01-18-2009, 06:03 PM   #16
Serge
OK thanks.....the original spring clips are there so I suppose they are good...
Squeaking from engine? merryprankster Non-Generation Specific Questions 0 06-23-2007 10:19 PM
