i have a mkIII with a 1jz motor and i was wondering if i could use 2jz cams? thanks
I am not sure that the 1JZ cams will work. Also depends on what 1JZ you have if it is the VVTI then you are pretty much out of luck. Which cams are you looking at?
1987 supra NA 5 speed 1JZGTE swap Tokico Illumina 2 and Eibach springs Tokico pillow blocks Suspension Techniques front and rear sway bar HKS super dragger cat-back exhaust plus test pipe Greddy Profec B spec 2 boost controller HKS type 1 turbo timer Supra sport solid steel drive shaft Walboro 255 fuel pump JZA70 Front end mod 18" Volk Racing AV3 18x8.5 front 18x9.5 rear |
im kinda new to the whole car thing i have a 1jz 2.5l twin turbo and a friend suggested getting cams and a fuel rail out of a 2jz motor
It seems like I have herd that you can do that.
But once you start swapping cams you start throwing off the vafm. I thought about gte cams on my ge. But to make it work you have to find a way to manipulate the vafm. And that means maf-pro. Tell your friend to hot rod his own shit. Before he helps you blow yours up. Supradaddy has some very good points as well. It will depend on years and all of that. Try not messing with perfection until you get it tweaked right and see if you dig it. You can't just mod these cars up. Especially with new cams. Research research research. Enjoy and Welcome. |
alright, thanks
Question about 7m-gte. | AzNbOi2626 | MKIII Supra | 3 | 03-29-2011 06:55 PM |
Starter Removal question | OkieRA29 | MKIII Supra | 13 | 05-11-2010 12:08 AM |
Pre89 versus 89+ nose and support. | lifesnotfair | MKIII Supra | 2 | 01-08-2010 09:06 PM |
Help! Question on front NOSE and bumper supports. | lifesnotfair | MKIII Supra | 1 | 12-26-2005 03:54 PM |
Quick question | AutoXMan | MKIII Supra | 12 | 09-30-2005 06:40 AM |
