#51 |
yeah. i think i found what it was. i had the charger on the old battery. the charger was on a 50 amp start, so it was getting a lota juice. one of my friends told me it was probably my alternator trying to make up for the added power going to the battery. so when i took off the charger for a few days and started it up last night, no whistle.
91' 7m-gte, sold ![]() |
#52 |
lol.. odd : )
My Links: What I am doing... http://www.toyota-supra.info/forums/...part-list.html My questions http://www.toyota-supra.info/forums/...w-answers.html |
#53 |
ok. i started it up last night cause i finally got my timing right and found the damn whistle. it was a vac leak.... haha. but anyways, i took it out for a nice slow spin around the block and as i take a corner gave it a little gas (maybe 3000 rpm) it starts to smoke again. im thinking the shop took off just a little too much from the head and the compression is too high therefore blowing another gasket. so i think i am done with this 7m. it has 201xxx miles on it so i really dont think it is going to last a few more years.
![]() what would i need for a direct drop in for a 1jz-gte. ecu?? would i need to re-route fuel and brake lines? would i need to make a new exhaust that would bolt up? i know the tranny still works but with a different bellhousing. ( am i correct???) and what do you think would be the final cost for everything?
#54 |
>"im thinking the shop took off just a little too much from the head and the compression is too high therefore blowing another gasket."<
Highly unlikely, especially if you haven't used full boost. I just reread this whole thread and didn't find any comments about it smoking before. What color is the smoke? Pull all 6 spark plugs and shine a small light into each cylinder. If you see any water, it's probably the head gasket again. If they are all dry, it's probably good. How much does it smoke? Maybe you can drive it thru the winter, save some $$$, and determine if the smoke is just valve seals/guides or rings/bearings. Worn rod bearings will throw a lot of oil on the cyl. walls, more than even good rings can handle.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein 1988 and 1990 Turbo Supras |
#55 | |
![]() Quote:
So.. my question is... you replaced the head gasket.. anything else? Others will correct this statement if I am wrong, but your farther ahead money-wise if you rebuilt the engine yourself. I wouldn't ignore the turbo though (this is a 7m-gte right?) but personally I wouldn't do the turbo myself because it has low tolerance for error. I am not a trained mechanic but have rebuilt a few engines long ago, and the rule of thumb then was, Head gasket gone? Do a valve job. When you do a valve job you do the rings... at that point... you just say.. oh what the hell and do the whole engine. Its not that much more money if your doing it yourself.. although I shudder at the thought of rebuilding a 7m-gte... ![]() mind you.. I would love to pull mine if I had a month of nothing much to do! I just make more money working then I do not working, so to me.. its cheaper to have it done.. plus I have someone to bitch at later if it doesnt work. ...then there's retooling for the job...
Thread Tools | |
Display Modes | |
