Old 07-20-2008, 01:09 PM   #31
Chambers
Chambers's Avatar
The 1JZ came with the R154 tranny, so you speedo cable will work. Start doing some research on 1JZ harness and computers, compared to your pre 89 harness.
All the info you need is out there, my advice would be to do a lot of research before you start tearing stuff down, that way you have all the knowledge about what you are doing before you do it.
You can buy engine mount adapter for your pre 89 that will allow the JZ engines to bolt up with your cross member, I my self would not completely trust the engine mounts without the 89+ cross member.
Hope this helps, Good luck.
"Stuck in the 80's"
Old 07-21-2008, 07:44 PM   #32
1989 8secmkiii owner
1989 8secmkiii owner is on a distinguished road
Default 1 jz
hey guyz check this out, i gotta custom made motor mounts for my pre 89 mkiii for 1 jz swap and i dont have to replace cross member. and one of my friend swaped 1jz using those motor mounts, they work. i got those from BIC performance.com
1989 8secmkiii owner is offline   Reply With Quote
Old 07-26-2008, 10:50 PM   #33
tsupra89
tsupra89's Avatar
tsupra89 is on a distinguished road
the stock bottom end ive heard will hold up to 900 hp if in good conidtion the bottom end is all forged internals. very strong the only thing is the tranny wont hold as much and the engine can so ull have to beef it up. second the hg on 7m's kinda suck u can run 16 max psi on the stock hg but u might blow it eventually but no worrys i have a 7m and im boosting 11 and i havent had a problem except a oil leak coming from where the distributor was from the previous models. and to make the boost go up the wastegate is connected by two bolts undo the bolts and put washers behind it i have 5 washers on each side and im boosting 10 to 11.
89 Supra Boosted 11psi
lexus afm
k&n air system
aeromotive fuel pressure regulator
walboro fuel pump
stage 3 weitght reduction
koki style tail lights
silver and black 2 tone paint
Enkei rs7 17" 17.5lbs each
hankook ventus hr2's 225/45/17
apc hood pins
yellow fogs
Soon To be
Megan racing seats, roll bar, either takata or sparco harnesses
tsupra89 is offline   Reply With Quote
Old 12-08-2008, 09:31 PM   #34
Default sale mkiii 7 mge parts.
hey, guyz any one needs parts from mkiii mge parts just let me know. i m parting out my car. tnx leave me a message for info regarding parts and pic. tnx.
Old 01-23-2009, 10:58 PM   #35
Default check engine light
hi guyz check engine light came on my car it is throwing code #2 which is VAF circuit . so if any one know about that let m e know thanks.
Twin turbo on 7mgte? supraman121 MKIII Supra 7 08-24-2007 02:12 PM
