Old 06-29-2008, 02:11 AM   #1
Chavez1
Chavez1 is on a distinguished road
Default Wiring (need help please)
I have a 1989 Supra NA with a bad body harness and i was hoping in maybe finding a replacement but i'm have no luck in locating one can anyone help please it will be very helpful
Chavez1 is offline   Reply With Quote
Old 06-29-2008, 02:50 AM   #2
Chambers
Chambers's Avatar
In what way is the body harness bad?
"Stuck in the 80's"
Old 06-30-2008, 02:33 AM   #3
Chavez1
There was a fire with the previous owner and the wires to the stereo were damaged and some of the damage goes all the way back behind the dash.
Old 06-30-2008, 12:22 PM   #4
Chambers
Chambers's Avatar
Ohh, that sure sucks. Well I would suggest you look into some local junkyards and parts pullers, but first you will need to determine what harness you have, pre-89 or 89+. If you didn't know, 89 was a transition year, some 89's have the old harnesses and some have the new ones. I think the pre 89 harness have yellow ECU plugs, and the 89+ have gray plugs. Good luck.
"Stuck in the 80's"
Old 07-01-2008, 09:04 PM   #5
robertsws
robertsws's Avatar
robertsws is on a distinguished road
i've seen 2 separate harnesses for sale on ebay in the last month.
1991 Supra - Turbo - 5spd
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
550cc injectors (2 sets, venom direct fit, RC engineering)
2.5" intercooler and piping
Aluminum radiator w/dual electric fans
ARP bolts w/MHG
Full-auto turbo timer
Fidanza Flywheel & Stage 2 Clutch
spark plugs and wires.
power steering pump
cold temp start switch
engine top end rebuilt
transmission opened up and inspected at a tranny shop when the flywheel and clutch installed last week.
robertsws is offline   Reply With Quote
87 Supra Wiring Harness slader99 MKIII Supra 9 04-28-2008 12:14 AM
question about wiring harness????? tone loc MKIII Supra 2 08-30-2006 09:20 PM
HKS VPC wiring diagrams cat007 MKIII Supra 0 11-07-2005 09:28 AM
