#1 |
ok so i rebuilt my turbo and screwed up the balance. i plan to have it re-balanced at the gpop shop in AZ but for now i bought a used stock turbo to use. got the turbo, inspected it, cleaned it up, and everything looked good.
turns out the turbo i had on originally wasn't stock, so i replaced an upgraded turbo with a stock turbo. now i am in a slightly more af a rush to send off mine to be re-balanced but I need transportation in the mean time so i left the stock turbo on the car. the problem is it idles good, high but good. when i step on the gas all power drops out. if I hold the gas down slightly then it lopes pretty bad. any ideas?
1991 Supra - Turbo - 5spd 60-1 upgraded turbo Lexus AFM 3" exhaust, 4" tip SAFC 2 550cc injectors (2 sets, venom direct fit, RC engineering) 2.5" intercooler and piping Aluminum radiator w/dual electric fans ARP bolts w/MHG Full-auto turbo timer Fidanza Flywheel & Stage 2 Clutch spark plugs and wires. power steering pump cold temp start switch engine top end rebuilt transmission opened up and inspected at a tranny shop when the flywheel and clutch installed last week. |
Thread Tools | |
Display Modes | |
