Old 07-02-2008, 07:25 PM   #1
robertsws
robertsws's Avatar
robertsws is on a distinguished road
Question upgrade advice
a quick rundown - new TPS, power steering pump, Spark plugs, belts, oil change, vacuum lines, upgraded BOV, upgraded IC piping, SAFC2, and 3" Exhaust. Cleaned TB, ICV, and intercooler. Replaced valve cover gasket and the 4 o-rings above the spark plug well.
I am putting an upgraded turbo and a lexus AFM on it next. Is there anything I need to do at the same time?
1991 Supra - Turbo - 5spd
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
550cc injectors (2 sets, venom direct fit, RC engineering)
2.5" intercooler and piping
Aluminum radiator w/dual electric fans
ARP bolts w/MHG
Full-auto turbo timer
Fidanza Flywheel & Stage 2 Clutch
spark plugs and wires.
power steering pump
cold temp start switch
engine top end rebuilt
transmission opened up and inspected at a tranny shop when the flywheel and clutch installed last week.
robertsws is offline   Reply With Quote
Buying supra need advice guys sisqojazz Non-Generation Specific Questions 1 03-21-2007 10:47 PM
***Need expert advice on a 2JZGTE swap in a Lexus*** sixfourbolt Non-Generation Specific Questions 4 08-27-2006 08:30 PM
If U Upgrade Exhaust Must U Upgrade Intake scruffboy Non-Generation Specific Questions 12 12-23-2005 06:35 PM
Upgrade CT-26 or New Turbo MK3Turbo MKIII Supra 2 06-09-2005 02:27 PM
