Old 01-08-2011, 10:08 PM   #1
88arpuS
88arpuS is on a distinguished road
Thumbs up Fixed starting problem, thanks
Thanks to Cyfi6 and Bill UK I was able to start my 1988 supra 7m-gte, I replaced the strarter which I tested and it was burned out, had problem with top bolt but was able to reach it with a 2 foot extension and universal socket with a 14mm attached and I reached it from the front of the car with my hand under the exhaust manifold and I used the weight of the starter to hold the bolt from moving while I unscrewed the nut. Then I jump started it and it started, but when I cut it off it wouldn't start again, so I came to this forum I purchased the 30 amp relay plus 18 gauge wire and wired it first based off the wiring diagram that Cy Fi6 posted and it didn't start so I wired it based off of Bill UK wiring diagram and it started right up and has continued to start everytime. I'm in chicago so it was very cold when I changed the starter out and put the relay in.
I could not have done it if this forum did not exist so thanks to this forum admin (cre) and a special thanks to Bill UK and CY fi6
88arpuS is offline   Reply With Quote
Old 03-31-2011, 10:52 PM   #2
83Billygoat
83Billygoat is on a distinguished road
I'm having similar issues. I think i'll try it. i'll repost after see if it helped
83Billygoat is offline   Reply With Quote
Old 04-09-2012, 02:30 AM   #3
RedAstig
RedAstig is on a distinguished road
Default Where?
had same problem...anyone has a diagram where the starter relay located? thanks.
RedAstig is offline   Reply With Quote
Old 04-09-2012, 06:41 PM   #4
The stock diagram? Here: http://www.cygnusx1.net/Supra/Librar...x?S=Main&P=038
Old 04-09-2012, 10:40 PM   #5
RedAstig
Hey Cre, I try to buy today at NAPA auto parts the starter relay and they said its not listed...where can I buy this? and I cant find where is it located inside my car so I cant take it out and show it to NAPA. please help thanks.
Starter Removal question OkieRA29 MKIII Supra 13 05-11-2010 12:08 AM
90 mkIII starter connections doodah MKIII Supra 1 11-11-2008 06:14 PM
How to quickly test starter CyFi6 MKIII Supra 4 11-30-2007 01:57 AM
1986.5 Starting Problem supraman121 MKIII Supra 4 09-03-2006 03:51 AM
engine noise car dies after starting tex1116 MKIII Supra 7 11-18-2005 06:47 PM
