Old 07-12-2008, 07:04 PM   #1
sevenmgte
sevenmgte is on a distinguished road
Default ECU question
can any one till me if an automatic ECU work on a manual car ?
sevenmgte is offline   Reply With Quote
Old 07-12-2008, 08:09 PM   #2
specialkmj7
specialkmj7's Avatar
specialkmj7 is on a distinguished road
This was a response to my ? on I-supra at the end its underlined but this should help a lil better than tellin u yes. lol
Posted July 03, 2008 06:08 AM July 03, 2008 06:08 AM Hide Post
quote:
Originally posted by Supra88T_Knight:
I have heard different things about ECU's mostly about turbo's. For an N/A though you shouldnt have to worry about what year, however I would recommend not to go backwards though as with newer models comes newer technologies.
Nope. 86.5-88.5 are the same ECU, using yellow plugs. 89.5-92 are gray plug, and the wiring pins are different.
They are NOT interchangeable.
quote:
You can use a newer ECU however. I Know some models have Some safety additions and then theirs TEMS as well.
So long as the ECU is '90-92, yes. TEMS has nothing to do with the ECU. It has it's own computer...
quote:
I'm not sure if that plays a factor but you should be able to use it regardless. Oh yeah make it sure it also fits your transmission type, thats important too.
It only matters if he's automatic. If he's got a manual, it doesn't matter at all. Manual cars can use automatic ECU's and wiring harnesses, but not the other way around.
specialkmj7 is offline   Reply With Quote
Old 07-12-2008, 10:29 PM   #3
supramacist
supramacist's Avatar
NO NO NO.
The automatic ecu is not the same as the manual ecu.
That's why they are clearly marked as to automatic or manual.
Old 07-18-2008, 10:58 PM   #4
sevenmgte
how can i tell if the ecu is not working? would it still crank?
Old 07-19-2008, 06:04 PM   #5
btwilson86
Super Moderator
btwilson86's Avatar
The engine would still crank, but if your ecu didn't work at all the engine should not fire. As for cranking the engine over, there's not computer in that circuit. It's just wires, fuses, switches, and relays.
What's your car doing that makes you suspect the ECU?
Old 07-19-2008, 06:33 PM   #6
sevenmgte
that's what the tech said, and when i got it home did a diagnose on it my self. the check engine light just flash none stop.
Old 07-20-2008, 07:06 AM   #7
btwilson86
Super Moderator
btwilson86's Avatar
So what's the car doing that's abnormal?
Old 07-20-2008, 03:39 PM   #8
sevenmgte
yea that's not normal. well i found another ecu the #'s almost matches mine check it out mine-89661-14240 17000-1471 his-89661-14280 175000-1511 so i was thinking since his #'s where bigger its a newer model right? so what u gays think bid end soon. i found it on ebay
Question about 7m-gte. AzNbOi2626 MKIII Supra 3 03-29-2011 06:55 PM
Starter Removal question OkieRA29 MKIII Supra 13 05-11-2010 12:08 AM
Pre89 versus 89+ nose and support. lifesnotfair MKIII Supra 2 01-08-2010 09:06 PM
Help! Question on front NOSE and bumper supports. lifesnotfair MKIII Supra 1 12-26-2005 03:54 PM
Quick question AutoXMan MKIII Supra 12 09-30-2005 06:40 AM
