Old 08-15-2011, 10:30 AM   #1
krash
krash is on a distinguished road
Default New to Forum as of today..purchased 1986.5 Supra two days ago
hello everyone....just picked up a 1986. Supra w/ 118k/5sp ..from original owner....Originated in CA....(yup, CA. emissions)....extremely well taken care of.....runs excellent....
problems; the following are not working:
1. air conditioner: fan working, just blowing warm air...
2. Fact Stereo w/cassette player: not working..
3. Cruise: Dash switch light goes on...but doesn't work when applying the wheel controls...
4. Horn....nothing, nada, kaputz...
Beyond these items, it runs excellent, shifts smoothly, no leaks anywhere,
no odd noises,....clean car
ID:	4147   Click image for larger version
Name:	86 supra-2.JPG
ID:	4148   Click image for larger version
Name:	1986 Supra-2.JPG
krash is offline   Reply With Quote
Old 08-15-2011, 11:05 PM   #2
El Supracabras
El Supracabras's Avatar
Nice car, don't krash it. I keed. Those are all common things for any old car, even more common on old supras.
If the a/c compressor doesn't engage check the fuse for the a/c first, then the refrigerant level.
Get a new stereo, stock leaves a bit to be desired even when it works.
Check the vacuum lines and wires to the cruise control servo by the brake master cylinder. Then make sure it is connected to the throttle.
If you hear a clicking under the dash when you hit the horn, it is either bad wiring to the horns or bad horns. If you hear no clicking, check the fuse.
Good luck and take your time with the car.
Old 08-17-2011, 02:55 AM   #3
MJG
MJG's Avatar
supracabras makes a good point.
The stock stero, when working is OK.
Replacing it with an aftermarket unit is well advised.
Old 08-17-2011, 02:28 PM   #4
Green7mgte
Supra Forum Moderator
looking at a factory supra stereo reminds me of my grandmothers rotary phone..
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
1986.5 Supra hyphy MKIII Supra 1 05-27-2009 03:33 AM
Supra Forum intertwined with other Imports Adam@D and A Hot Impotrs Off Topic Forum 1 06-20-2005 11:18 AM
