Old 07-28-2008, 11:55 PM   #1
Daithan
Daithan is on a distinguished road
Default A/c
Anyone know where the fuse for the A/C is located? Can't seem to find it anywhere in the owners manual.
Thanks.
Daithan is offline   Reply With Quote
Old 08-07-2008, 12:22 AM   #2
Daithan
Hey, thanks for the advice! Not!
Well, here some for you:
If you want to correct the dreaded "hatchback " thunk" when going over bumps just line the inside back edge with felt floor furniture pads, available at your local WalMart. Takes up the space that's between the back body edge and back hatch lip.
Boink! - Worked for me.
Daithan ( anyone know that where the name Daithan comes from? )
Old 08-07-2008, 04:10 AM   #3
RNEMESiS42
RNEMESiS42's Avatar
RNEMESiS42 is on a distinguished road
I thought I just had a crappy hatch! I'll try that out...every time I go over a bump I think I left my trunk open...
White 1987 N/A. Automatic. Targa top. TEMS
RNEMESiS42 is offline   Reply With Quote
Old 08-07-2008, 12:04 PM   #4
Chambers
Chambers's Avatar
Thanks.
Its located in the right kick panel, its a 10A. The only other fuse there should be for the blower motor, 30A.
Make sure when you go to pull the panel off you take the door sill out first, then the 10mm nut at the rear of the panel.
Good luck.
"Stuck in the 80's"
