Old 08-08-2008, 11:52 PM   #11
RNEMESiS42
RNEMESiS42's Avatar
RNEMESiS42 is on a distinguished road
Thanks for the links there : D
I'm guessing I need to replace the bulbs, but maybe the wiring is shoddy, because the spoiler brake light doesn't work either.
White 1987 N/A. Automatic. Targa top. TEMS
RNEMESiS42 is offline   Reply With Quote
Old 08-09-2008, 12:03 AM   #12
supra_91
supra_91's Avatar
you might have to replace your tailight failure box. its right in front of your drivers tailight behind the panel. its about 2" x 2" x 1". i think yours is yellow because its an N/A. mine was but then i put the spoiler on and had to change to the white one so that it would send the correct voltage to the spoiler to light up the led. yours maybe be white though b/c you have more options on yours than i have
Old 08-09-2008, 02:41 AM   #13
RNEMESiS42
RNEMESiS42's Avatar
Really? I already pulled it and opened it up and everything looked fine. It's yellow. My dash doesn't even show that some of my tail lights are messed up (even though that's what the box is supposed to do). Maybe it just crapped out, even though I can't see any burn marks or shoddy soldering.
Old 08-09-2008, 06:37 AM   #14
btwilson86
Super Moderator
btwilson86's Avatar
I may be wrong, but didn't the spoiler only come on Turbo models? My 87 N/A has almost all of the options and it never had a spoiler...
I have a third brake light in the window, so maybe whoever put the spoiler on there (if it's not a stock piece on any N/A's) didn't switch out the box. Also, the Yellow box I believe is for the pre-89 supras and white is for the post-89 models. If you have a 3-piece spoiler than you should have the white box (if what I stated is true; someone please correct me if I'm wrong).
Also, if you have the 89+ lights (with the red piece in the middle) you would also need the white box.
Old 08-09-2008, 11:09 AM   #15
RNEMESiS42
RNEMESiS42's Avatar
Well, it's a spoiler like this one:
I don't know if that qualifies as a spoiler (for lack of a better word) or not. As far as I know, my car is completely stock, except for replacement parts that have failed.
Old 08-09-2008, 03:25 PM   #16
btwilson86
Super Moderator
btwilson86's Avatar
Okay, that is the pre-89 spoiler, so your Yellow Box should be the correct one. Well, I was hoping I could help you out with this but that's pretty much all I can think of...
You might want to use a Volt Meter and check for Voltage fluctuations out of the sending unit when someone presses on the brake. I don't know what the power is supposed to be, but if it's working there should be a change.
Old 08-10-2008, 12:20 AM   #17
supra_91
supra_91's Avatar
mines a 91 N/A and i had the yellow box. the way i understood it was that all N/A's had the yellow box and turbo's had the white box. could be wrong. its possible that whomever bought the supra new ordered an N/A with a spoiler...just a thought
Old 08-10-2008, 12:53 AM   #18
Jet Krosswind
Jet Krosswind is on a distinguished road
I had a problem with all the electronics in the back going berserk about a month ago. Did you check your ground screws? That was my problem and all I did was tighten them.
Jet Krosswind is offline   Reply With Quote
Brake light Help ethan12510 MKIII Supra 4 07-31-2007 02:57 AM
Spoiler Brake Light Info Bill UK MKIII Supra 0 10-27-2006 10:06 PM
Hand Brake Light 88Supra Non-Generation Specific Questions 8 08-18-2006 01:35 PM
battery warning light / tail lamp failure warning light MattJ MKIII Supra 5 02-06-2006 07:22 PM
