-   -   head gasket (http://www.toyota-supra.info/forums/mkiii-supra/12-head-gasket.html)
mmitchell1 08-16-2004 05:52 PM
I was told by an owner of an 89 Supra, that Toyota had a recall due to the faulty design of the head gasket on the Supra. I have an 86 that blew the head gasket recently at 72K. Does anyone know if this is realistic that Toyota would do this for cars 15-20 years old. If so, do you know how to contact them regarding the matter. The owner has only had the car 2 years.
WRX 08-18-2004 01:31 AM
No, man. I believe its impossible... They dont care about for cars above 5 years old.
suprra_girl 08-19-2004 06:33 AM
Hey :)
Toyota didn't do a recall for a head gasket design
what toyota did wrong was they only torqued the head to 58ft pounds whereas it should be 75ft pounds
to get your 86 done properly, you need brand new head bolts or upgrade to arp head studs, an aftermarket head gasket will do well... you can either spend the money on a brand name hks greddy etc or get a custom metal head gasket... metal head gasket is definitely the way to go
get your head and block surfaced and get the engine reconditioners to crack test and pressure test it and check for softness, if your head is all good not warped etc and your block hasn't got any bad pitting or corrosion then a metal head gasket, new head bolts and torqued to 75ft pound should be sweet as... if you need any help regarding this send me an email or check out my site www.supra.co.nz and i'd be happy to help :)
suprra_girl@hotmail.com
Good luck
Suze
mmitchell1 08-21-2004 03:43 AM
Thanks for the replies. I appreciate it.
ozsupra 10-01-2004 07:41 AM
even though i didnt reply...........on behalf of those who did........your welcome :)
sbrander 10-02-2004 09:50 AM
LoL :P
ozsupra 10-02-2004 11:37 AM
dont poke ur tongue out at me little man
MA70-1JZ 10-10-2004 06:43 AM
sounds like a good buy to me..just torque the head and you are away
Sir_Kyle 03-22-2005 03:08 AM
hey,
just wondering if a warped head is common in '87's and if a warped head could b confused for a blown head gasket, and if these problems arise on NA models
thanks
email with response
kyle_leonard9@hotmail.com
