Old 08-15-2008, 12:57 AM   #1
skadaloz
skadaloz is on a distinguished road
Default Question About 7mgte Rebuilt
Like The Title Says...does Anyone Know How Much It Cost To Rebuilt The 7mgte Motor...give Me An Average...if Its More Than $1000 Then I Mine As Well Get A Jdm 7mgte...b/c I Know My Head Is Crack Somewhere...well Thats What I Was Told...burning Oil/coolant Like A Mother F-er...dies Sometime After U Beat It And Put It To Neutral...some Of My Exhaust Manifold Studs On The Head Is Stripped...turbo Leaks....so What Do U Guys Think...buy A Jdm Motor Or Rebuilt The One I Have?
skadaloz is offline   Reply With Quote
Old 08-15-2008, 02:24 AM   #2
Chambers
Chambers's Avatar
Ehh, cracked head, thats no good!
I would say you should get a JDM engine, the only thing is you may want to do a light rebuild on that, just because its a JDM engine with low miles doesn't mean that it want abused.
I would say spark plugs, spark plug wires, piston rings, a full engine bearing kit, main and head studs, MHG, timing belt, timing belt tensioner, water pump, oil pump, engine gasket kit, and some machine work to ensure that the MHG will hold.
I have done some searing on a light re-build for a 7M-GTE, I came up with a total of about $1200, without machine work. The machine work will really depend on what condition the engine is in.
Good luck.
"Stuck in the 80's"
Old 08-15-2008, 09:53 AM   #3
azerty
azerty's Avatar
azerty is on a distinguished road
A new head alone is around or over 1.000$, but be sure that the JDM will need some time and money also.
If 1.000$ is all you`ve got, I`ll say JDM, but be aware that a Supra isn`t a car to go cheap on.
1988 yelow manual turbo targa
HKS ssqv bov
Hose Techniques silicon hoses
Forge manual boost controller
boost gauge
K&N FIPK
ACT clutch kit HD-G6
Fidanza lightened flyweel
550cc RC Injectors
255lph Walbro Fuel Pump
LIPP Lexus AFM Replica
3" turbo back echaust with divorced
downpipe and no cats.
Aeromotive FPR
Aem Uego Wideband Gauge+O2 sensor
azerty is offline   Reply With Quote
Old 08-15-2008, 11:14 AM   #4
Chambers
Chambers's Avatar
If you do have to do a rebuild on a tight budget, this place has cheap stuff, just beware you get what you pay for.
Toyota stuff:
Toyota 6 Cylinder
"Master" Rebuild kit:
Toyota 3.0L 7MGTE - Master Rebuild Kit 87-92
Good luck.
"Stuck in the 80's"
Garrett turbo question GARRETT T3/T04E TO4E 60 Trim Stage III Turbo Burning Pyro MKIII Supra 1 10-24-2007 09:29 PM
The 7mGTE and the Tranny question panda-supra MKII Supra 5 10-10-2006 02:25 AM
