#1 |
Like The Title Says...does Anyone Know How Much It Cost To Rebuilt The 7mgte Motor...give Me An Average...if Its More Than $1000 Then I Mine As Well Get A Jdm 7mgte...b/c I Know My Head Is Crack Somewhere...well Thats What I Was Told...burning Oil/coolant Like A Mother F-er...dies Sometime After U Beat It And Put It To Neutral...some Of My Exhaust Manifold Studs On The Head Is Stripped...turbo Leaks....so What Do U Guys Think...buy A Jdm Motor Or Rebuilt The One I Have?
#2 |
Ehh, cracked head, thats no good!
I would say you should get a JDM engine, the only thing is you may want to do a light rebuild on that, just because its a JDM engine with low miles doesn't mean that it want abused. I would say spark plugs, spark plug wires, piston rings, a full engine bearing kit, main and head studs, MHG, timing belt, timing belt tensioner, water pump, oil pump, engine gasket kit, and some machine work to ensure that the MHG will hold. I have done some searing on a light re-build for a 7M-GTE, I came up with a total of about $1200, without machine work. The machine work will really depend on what condition the engine is in. Good luck. |
#3 |
A new head alone is around or over 1.000$, but be sure that the JDM will need some time and money also.
If 1.000$ is all you`ve got, I`ll say JDM, but be aware that a Supra isn`t a car to go cheap on.
1988 yelow manual turbo targa HKS ssqv bov Hose Techniques silicon hoses Forge manual boost controller boost gauge K&N FIPK ACT clutch kit HD-G6 Fidanza lightened flyweel 550cc RC Injectors 255lph Walbro Fuel Pump LIPP Lexus AFM Replica 3" turbo back echaust with divorced downpipe and no cats. Aeromotive FPR Aem Uego Wideband Gauge+O2 sensor |
#4 |
If you do have to do a rebuild on a tight budget, this place has cheap stuff, just beware you get what you pay for.
Toyota stuff: Toyota 6 Cylinder "Master" Rebuild kit: Toyota 3.0L 7MGTE - Master Rebuild Kit 87-92 Good luck. |
Thread Tools | |
Display Modes | |
Garrett turbo question GARRETT T3/T04E TO4E 60 Trim Stage III Turbo | Burning Pyro | MKIII Supra | 1 | 10-24-2007 09:29 PM |
7mgte and 7mge question | supraman121 | MKIII Supra | 2 | 01-12-2007 09:09 PM |
The 7mGTE and the Tranny question | panda-supra | MKII Supra | 5 | 10-10-2006 02:25 AM |
