Old 08-21-2008, 12:25 AM   #1
frostburn
frostburn is on a distinguished road
Default ARP Head Studs
hey ok so.... i got my tranny fully bolted in and was working on the head when i came across the torque specs in the repair manual and it said torque the head studs down to 55-61 psi... now that threw me for a loop because i always thought there was suppost to be a way higher psi mark... but i torqued them to 61 as the manual requested, now i was going to put the cams back in and set up the camshaft angle sensor but im afraid that my ARP's arnt torqued enough? is that the right specs? ... also i was wondering if i can use synthetic oil in my 89 supra turbo... i was told that the synthetic ate away at my lines... not to sure if this is true or not so figured id find out first... and what type of oil should i be using? 10W30? 5W30? confused supra owner in need thanks guys
Mike-MK3
frostburn is offline   Reply With Quote
Old 08-21-2008, 06:13 AM   #2
btwilson86
Super Moderator
btwilson86's Avatar
First, there are alot of threads on here talking about the torque specs for the head... Just go with what the ARP studs say to torque them to. I believe that's around 80 ft/lbs.
As for the oils, I don't know for sure on that so I'll let someone else answer rather than guess for you
Old 08-21-2008, 04:47 PM   #3
Chambers
Chambers's Avatar
You can certainly run full synthetic in your Supra, the only problem is that synthetic will eat away any grit and grime that lines your gaskets and could cause a leak. How many miles are on your engine?
I use full synthetic AMSOIL in my car, I run 10W40 in the winter and 20W50 in the hotter summers.
Hope this helps, good luck.
"Stuck in the 80's"
Old 08-22-2008, 03:47 AM   #4
MK3PIMP
MK3PIMP's Avatar
MK3PIMP is on a distinguished road
Use 20/50 Gtx
MK3PIMP is offline   Reply With Quote
Old 08-22-2008, 03:50 AM   #5
frostburn
i have 37k on my engine brand new no rebuilds... but im not to sure about the lines there is 177k on the body.
Head studs on fresh motor? mnemonic345 MKIII Supra 0 03-02-2009 01:10 PM
ARP head bolts or studs? mirage83 Non-Generation Specific Questions 0 03-19-2008 10:09 PM
Head Bolts, Or Head Studs?? ZauggIt1 MKIII Supra 2 08-08-2006 01:23 PM
Head studs, headbolts, mainstuds. Black'88 Non-Generation Specific Questions 6 04-17-2006 09:03 PM
Torque Specifications (ARP Head Studs)??? Dejvid1785 MKIII Supra 5 03-06-2006 02:59 AM
