Old 08-25-2008, 09:36 PM   #1
ricangsxrdude
ricangsxrdude is on a distinguished road
Default 86 MkIII A/C charging help
I'm trying to locate the A/C charging port on my 86 MkIII.. Also if anyone knows what type refrigerant I need that would help out a lot too.. Can anyone help me out??? Thanks a lot!! Also I'm looking for spare parts for my car (especially the passenger door outer trim in brown).. Thanks for the help!
1986 Toyota Supra MkIII
7MGE 200 hp 5 Sp
ricangsxrdude is offline   Reply With Quote
Old 08-25-2008, 09:47 PM   #2
Grandavi
Grandavi's Avatar
I have the same issue with my 88. A refrigeration guy can do it, but I dont know if the dealerships will anymore because of the old coolant (CFC's).
Anyone had to do this on a MKIII yet?
I will post here if I figure it out.
Old 08-25-2008, 09:59 PM   #3
paulmicin
paulmicin's Avatar
paulmicin is on a distinguished road
You can refill it from here
using freeze 12. Freeze 12 Freon Replacement: EPA Approved!
1989 5 speed turbo
Koyo radiator
Spearco intercooler
HKS bov
Greddy e-01 boost controller
245's all around
Slotted + drilled all around
3" straight piping turbo-back, 4" tip
Lowering springs
HKS mushroom air filter
paulmicin is offline   Reply With Quote
Old 08-25-2008, 10:22 PM   #4
Grandavi
Grandavi's Avatar
I looked around as well. Being as I am in Canada, I think retrofitting or retrofitting to use Freeze12 is my only option. Here it will cost me 400-500 to retrofit my 88. Bah! I would do it myself.. but this isnt something I want to dabble in. Looks a little dangerous.
Old 09-08-2008, 05:16 PM   #5
ricangsxrdude
I noticed that there is a connection that looks like a filling cap near the trunk release on the front of the car. It directs to a sight glass so I was wondering if that is the right spot. Can anyone give me any pointers or am I looking in the wrong direction?
7MGE 200 hp 5 Sp
Old 09-08-2008, 06:54 PM   #6
CyFi6
Thats the high side port, fill into there and youl explode a refrigerant can in your face... Dont do this unless you are experienced.
Old 09-08-2008, 07:01 PM   #7
ricangsxrdude
So I should do it from the port near the battery then huh? Like on the picture?
7MGE 200 hp 5 Sp
Old 09-08-2008, 07:19 PM   #8
CyFi6
I think you shouldn't do it at all without a good knowledge of how the system works and how to diagnose it. A/C work isn't for the inexperienced, you've got to learn it all by the book before you can go out and work on a car, it can be very dangerous. And your car needs R12, a refrigerant you cant even buy without a 609 cert.
Old 09-08-2008, 11:55 PM   #9
ricangsxrdude
So pretty much it would be pointless to get the R-134 conversion kit then huh?
7MGE 200 hp 5 Sp
Old 09-09-2008, 01:57 AM   #10
Grandavi
Grandavi's Avatar
Well.. as said.. if you want to become an expert, go for it.. but first become the expert. Its just a dangerous area to play if your a novice.
Me, personally, Im just having it done. Would rather spend the 500 to have my conversion done properly by a trained person. In the end, its just safer and wont cost me more due to "my mistakes".
Having said that, of course... I dont think its that hard providing you study what your doing prior to doing it, and make sure you have all the tools. The write-ups are pretty self-explanatory and I thought it wouldnt be that hard to do correctly.
However, I still make math mistakes that I am 100% positive they are correct until after I double check.
Turbo Charging mkiii supra supraflymk3 MKIII Supra 4 05-24-2008 03:11 AM
