I just purchased new Bosch Platinum 4 plugs and want to install as I was having some issues from a ancient plug. Does anyone have a torque spec for install on a 87 turbo ?
I don't know if those plugs are to be used with our vehicles, but to install plugs use 16mm Plug Wrench and torque to 13 ft-lb as stated in the TSRM
Im currently using the bosch platium 4 plugs and I like them there is something that is messed up with my car before the upgrade but I did noticed a definate hp increase. I also got some ngk wires and those also help alot.
Supra Engine Powered Dragster |
A little late but I'm pretty sure you don't want to use platinum plugs in the turbo supra. Apparantly they burn TOO hot. This is just what i've been told from a few reliable resources
Yea, I would never run any Bosch plugs in a Supra of any kind, go for some NGK Iridiums, they will be a little more expensive but well worth it, they are high quality plugs. I don't have Iridiums but I have their regular plugs and set of their wires, they are both great!!
Good luck. |
#6 | |
![]() Quote:
Broken spark plug! HELP! | supraman121 | MKIII Supra | 2 | 10-02-2006 08:40 PM |
spark plug change | supfoo514 | MKIII Supra | 4 | 06-30-2006 07:41 AM |
new mk3 owner, spark plug galley full of oil!???? | katillidie | MKIII Supra | 6 | 03-24-2006 05:09 AM |
spark plug wires | kewlcoconut | MKIII Supra | 2 | 03-19-2006 07:45 AM |
spark plug change ? | frank323 | MKIII Supra | 1 | 04-03-2005 07:03 PM |
