Old 09-08-2008, 03:52 AM   #1
mkiiisupra
Default Oil Leak
I have oil pooling in the bottom section of my IC pipe'n where it mates to the IC. The pipe leading up to the turbo is completly dry.
Any ideas on what would cuase this?
1990 Toyota Supra Turbo A/T
Old 09-08-2008, 12:52 PM   #2
Chambers
Chambers's Avatar
By pooling what do you mean, fresh oil or tacky old oil?
Is your oil cooler lines leaking?
"Stuck in the 80's"
Old 09-09-2008, 12:02 AM   #3
mkiiisupra
Oil seems to be pretty fresh, other than what had seeped through the silicone coupler. And by pooling i mean seems to have drained to lowest point in the IC pipe'n and is sitting there slowly leaking through the coupler.
Oil doesnt seem to be coming from the bottom of the turbo, clean IC hard pipes from the oil pool to the bottom of turbo.
Heater Union (Coolant Leak) slader99 MKIII Supra 11 12-28-2009 12:29 AM
Oil Leak. supramacist MKIII Supra 0 05-01-2008 01:18 AM
Coolant Leak bossman MKIII Supra 2 04-12-2008 09:31 PM
Oil Leak Question kidsusukigsxr Non-Generation Specific Questions 2 06-26-2007 03:17 PM
gas tank leak burton51m MKIII Supra 14 11-24-2006 06:16 PM
