Old 09-07-2008, 05:13 PM   #1
mnewxv
mnewxv is on a distinguished road
Default what kinda power can I expect with these upgrades?
Right now I have an all stock 90 supra non turbo, manual, with a few year old stock exhaust.
what kind of power increases can I expect from a K&N FIPK intake and pacesetter catback? thanks
mnewxv is offline   Reply With Quote
Old 09-08-2008, 07:41 PM   #2
mnewxv
anyone?
Old 09-08-2008, 09:58 PM   #3
SideWinderGX
Get a rerouted Divorced Down Pipe (DDP) along with those upgrades and you'll notice a BIG difference. Numbers, however, depend on many variables. Lets say somewhere between 50 and 75 ish? More depending on how strong your engine is and if its manual or not.
my car:
Old 09-08-2008, 10:06 PM   #4
mnewxv
NON TURBO manual. I was hoping for about 25hp increase with the intake and catback. reasonable?
Old 09-08-2008, 11:30 PM   #5
shiftysupra
shiftysupra's Avatar
Thats Pretty reasonable, however I would also upgrade to a high-flow cat-converter as well as headers. all those you could expect around 75 hp gain
Old 09-08-2008, 11:36 PM   #6
Chambers
Chambers's Avatar
Ehh, 25hp may be what you get, you will get more with a test pipe but then you wont pass emissions, a cat back will help more than the cone filter unless the cone filter is rerouted under the head light, but then you run the risk of getting water in it when driving in the rain. You can get a lot more intake noise and a little bit more flow by removing the resonator but in the end the engine was designed to have it, so it may hurt you in the long run.
If you keep the resonator and just replace all the factory accordion hoses with new stuff that would help more than just a cone filter. The big cylinder you have between the throttle body and intake cone is the resonator, that actually helps straiten air waves as they move into the intake.
I don't prefer any of the available headers, they are not really tuned for the engine, certain pipes need to be certain lengths, thats why I'm designing my own.
A good exhaust and intake will make your car more fun to drive and hear, hope this helps, good luck.
Here is one of my concepts:
"Stuck in the 80's"
Old 09-09-2008, 12:08 AM   #7
SideWinderGX
I didn't see the non turbo part, my bad. =X
All those upgrades, plus a high flow cat or even a straight pipe....cut my numbers in half about.
my car:
Old 09-09-2008, 01:50 AM   #8
mnewxv
if money wasnt an issue...
but I get the pacesetter catback and K&N FIPK for under $400 shipped together so thats about where I want to be.
Old 09-10-2008, 03:09 AM   #9
kwnate
15 flywheel hp at the most.
Nate
Greetings! importauto Import Auto Center 7 06-21-2009 07:42 AM
no spark chrism8799 MKII Supra 6 12-08-2008 12:38 AM
Before buying an 85 P Supra with 123k what to look for e30cabrio MKII Supra 0 02-24-2008 08:09 PM
6 point Roll Cage? carl johansson Road Racing & Autocross 0 12-01-2007 12:28 AM
6m ge with turbo, what kinda power? Freezenpop MKII Supra 2 02-05-2006 01:09 AM
