Old 09-21-2008, 01:33 AM   #1
cgreiner
cgreiner is on a distinguished road
Default Transmission fluid check
I climbed uner the supra today to try and check the transmission fluid for the first time. I could locate the proper plug though. I noted two plugs near the back. One on the left side, about halfway up the transmission, and one on the right near the bottom (if on back with feet towards front of car). They are both hex and about the size of a quarter. Is either of these right ??? Any one have a picture ?
cgreiner is offline   Reply With Quote
Old 09-22-2008, 02:09 AM   #2
Busted Knuckles
Busted Knuckles's Avatar
The one on the bottom is the drain. The one on the side is the fill. It is considered full if a little bit of gear lube dribbles out when the plug is removed. If not, put a finger in the hole, and it should touch gear lube. If not, your low.
Transmission Fluid capacity suprabahamut Non-Generation Specific Questions 2 09-18-2008 04:30 AM
Transmission Fluid Change shiftysupra MKIII Supra 2 09-16-2008 11:21 AM
transmission fluid suprabahamut MKIII Supra 2 08-12-2007 06:04 PM
Draining Transmission Fluid? RNEMESiS42 MKIII Supra 20 05-17-2007 10:17 AM
Transmission Fluid Change phillip_o_hj Non-Generation Specific Questions 7 02-09-2007 08:56 PM
