Old 09-22-2008, 12:59 AM   #1
Serge
Serge is on a distinguished road
Default Mirror Control doesn't work
Hi All !
Who knows how to get an access to the mirrro control unit? I'm having troubles with taking of this part of the center console apart....something is holding it near shifter handle...
Thanks!
88supra 7MGE
Serge is offline   Reply With Quote
Old 09-22-2008, 07:34 PM   #2
OkieRA29
OkieRA29 is on a distinguished road
There should be a screw in the bottom of the coin compartment in front of the mirror controls. There are also two screws at the bottom back of the center console. Remove those three screw and the console lifts out. This is after you have removed the insert covering the shifter and AC controls. Once the console is removed, just unplug the electric lines running to the mirror controls. Just did this last night to clean mine up. It was sooooo nasty the square control would not even rock!!!!!
OkieRA29 is offline   Reply With Quote
Old 09-23-2008, 01:51 AM   #3
Serge
Okay thank you!
Now I have a trouble with this Center Finish Panel....Do we have any screw under this small plastic cover? I jusy absolutely can't take it off...
Thanks!
Old 09-23-2008, 02:12 AM   #4
OkieRA29
Every one I have ever taken off... two in total right now have just popped off. It takes a little wiggling as the top of the center panel is sort of hooked under the instrument cluster. Once you have it off, you need to unplug the hazard switch from it's cable to get the panel out. Then, I believe that there are two screws for the center console under the shifter console. Hope this helps you
Old 09-23-2008, 01:28 PM   #5
Serge
Thanks! It's done...so how did you clean this switch? Do I have to take it apart?
Old 09-24-2008, 01:40 AM   #6
OkieRA29
I very carefully pulled the bottom off of the switch and promptly screwed everything up. When you take the bottom off of the switch do it upside down. There is a metal plate that I have no idea how it goes back into the switch. Once the bottom is off and the insides taken out, the rocker square pops out. I then just used soap and water and a soft toothbrush. There are four prongs that stick out on the bottom piece that you need to pry out. I was able to get three pried out and then worked the bottom piece out. The circut board, which is the bottom piece, I cleaned with windex and q-tips. If you get it apart and see how the metal piece fits in, let me know. I have one more switch, but I haven't pulled it apart yet.
Old 09-26-2008, 01:31 PM   #7
Serge
I didn't take it apart....I just took a bottle of 96% alcohol and washed this switch in it for 3mins....it works now.
Best regards!
Old 09-26-2008, 01:37 PM   #8
OkieRA29
Wish I'd thought of that! At least I have one more to use if I messed up the first. Glad to hear it is working now
Headlights only work on High Beam - is it a fuse? t4yl0r10 Non-Generation Specific Questions 8 01-18-2008 03:56 PM
Speedometer Does Not Work! justin1642 MKIII Supra 8 07-23-2007 10:56 PM
Dash lights Don't Work supra67 Non-Generation Specific Questions 4 09-05-2006 04:58 AM
Dash lights Don't Work!! supra67 MKIII Supra 0 08-10-2006 01:11 AM
